I NEED HELP WITH MY BUILD PLEASE -FROST
frostflameful
7
Hello... I am a first time builder, so I would like some help. I am going to order my parts soon, so I would like to get you pro builder's input first. Here it is. I am going to be doing mild gaming, mostly minecraft recording. I do not need RAM, keyboard, or mouse. I am going to buy a monitor for $100, and here is my build.
PSU: XFX Core Edition 550w Modular 80 Plus Bronze
GPU: Sapphire Radeon HD 7770 1GB
CPU: AMD FX 8320
OPTICAL: Asus 24x DVD Burner
CASE: Raidmax Blade White
HDD: Western Digital Caviar Blue 750gb 64mb 7200rpm, WD7500AZEX
MOBO: Biostar TA970 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX
I think this build will be able to record on max settings on minecraft with 30+ fps. I am also going to have 16gb of 1866mhz ram. I already bought that. Please give me suggestions and improvements. I will be ordering this as soon as I get some feedback. THANK YOU -Frost
frostflameful
7
Okay about the case. I will look into that. I would prefer to stick with the 8320. I like the 8 cores better, and I would save a bit of money. I am on a strict budget and cant have any more than $10 above $800 total.
frostflameful
7
Hows this?
CPU: AMD FX 8320
CASE: Cooler Master Elite 431
MOBO: ASRock 970DE3/U3S3 AM3+ SATA 6Gb/s USB 3.0 ATX
