Question I need help with my VGA
so i was playing death stranding game for the first 2 hours everything was fine. but after that i started to experience errors in the game, like world objects not rendering properly and crashing black screen after that.and then i test my GPU with OCCT and start 3D standard to my surprise there is 2289 error detected, can someone help me with any suggestion that might fix this?
Update your post to include full system hardware specs and OS information.
Include PSU: make, model, wattage, age, condition (original to build, new, refurbished, used)?
Disk drive(s): make, model, capacity, how full?
Is all important data backed up away from the system in question and is that backup data verified to be recoverable and readable?
CPU : AMD RYZEN 5 3600
Vga : amd radeeon Vega 64 8gb MSI
RAM : Team group 8x2 ddr4
Motherboard : asrock steel legend b450
PSU : Corsair 750w Gold
Disk : m.2 adata 980 80%full
Harddisk 2tb 80% full
I buy this PC from 2022 Used
I link the photo from OCCT 3D standard test
https://postimg.cc/Hc53vtTS
This GPU?
https://us.msi.com/Graphics-Card/Radeon-RX-Vega-64-8G/Specification
Look in Reliability History/Monitor and Event Viewer for additional error codes, warnings, and even informational events that may be being captured just before or at the time of gaming problems.
The graphics card recommends a 750 Watt PSU.
My thought is that the PC's PSU is starting to falter and fail. May no longer be fully able to meet the power and performance requirements of the GPU and entire PC as a whole.
Reactions: Hotrod2go
This GPU?
Yes that GPU
So that mean my GPU is fine? No damage on the component?
I would like to say that the GPU is fine. And hopefully it is.,
However, power problems can be damaging.
Not familar with OCCT and how well it correctly finds and identifies problems.
If possible try the GPU in another known working system. Determine if the problems continue.
