Hi there stranger
. I want to build myself a Homer Server and would require some help, sorry if it is a long post, but I included everything I thought could be needed below.
Information:
My planed build:
My questions are:
That would be all the info I could think of right now and all the questions I still have. I am more the software kinda guy, so hardware is not my real strong suit. I hope someone here can help me out a bit, so I do not make any dumb decisions and go into this as prepared as possible. Thank you all for reading and anyone helping I thank in advance also. Have a nice day stranger
Information:
- Budget (including currency): around 2.200€ (2.270 USD)
- Aim:
- It should be as power efficient as possible
- The system should function as a NAS for myself and close family
- Movie and Audio streaming
- Development Server
- Home Lab
- VMs
- Docker Services
- Software:
- OS: TrueNAS Scale
- Family connectivity:
- DuckDNS to connect to my router with dynamic IP
- Reverse Proxy to connect to the services which shall be exposed over the internet through DuckDNS
- OpenVPN for connection to development services
- Nextcloud for account separated access to data like photos and documents
- Streaming: Plex for movies and series, for audio has not been decided yet
- Other Info:
- TrueNAS with ZFS file system
- 2 VDEVs á 4 * 8 TB drives
- RAIDZ2
My planed build:
- CPU: AMD Ryzen 7 5700G
- CPU Cooler: Stock ?
- Motherboard: ASRock X570M Pro4
- Memory: Crucial Pro CP2K16G4DFRA32A DDR4 RAM Kit (2x16GB) 3200MHz
- Boot & Cache Storage: Samsung 970 EVO Plus 500GB NVMe M.2 SSD
- Data Storage drives: 4x Seagate IronWolf 8 TB NAS HDD
- Power Supply: Seasonic Vertex PX-750 ATX3.0 750W Vertex PX-750
- Case: SilverStone Technology SST-CS381 v 1.2
My questions are:
- Is there anything you would change about this build? Knowing what it will be used for, is there anything in particular you would change? I hope I didn't mismatch any parts, but this is not my primary forte so any head ups are gladly received.
- What would you recommend for fan configuration? I am either going to use the Stock cooler or one from Noctua. Which one would you recommend? Other than that, I am not quite sure how many case fans I would need and in which push or pull configuration. That's why I haven't listed them above. I want to make sure that nothing gets too hot even under load, but I have no experience with it.
- What RAID configuration would you recommend? I have looked into this a bit and I think I want to use the ZFS file system with TrueNAS. For now I would buy four 8 TB drives which will become my first VDEV. I thought I would use the RAIDZ2 which would give me 16 TB of usable space and quite a high fault tolerance, but would that be needed? If I need more space I would add another VDEV of four drives in the same configuration. I like the data to be as save from corruption as feasible, but should I rather use RAIDZ1 or another RAID altogether. What do you think?
- Do I need any additionals? Like cables or something like that, which I might forget.
- What about GPU? I am thinking about adding a GPU for hardware transcoding for PLEX for example at some point. Is that even needed and if that is something which you would recommend, what is a good card for my configuration?
- OPTIONAL: Backup strategy? This is a optional question, but because family will also store data on this machine I am thinking about what I will do for backups. For me I wouldn't care too much, but with them in the mix. Are there any cloud backup services you could recommend? If not I may be just going with some good old hard drives stored with a friend.
