[SOLVED] I need your advice for upgrading my build
DeMo5h5
47
Hello currently my pc specs are
I5 6500
2x4GB RAM hyperx fury
Gb b150 mobo
Rx580 8gb
What is your advice to upgrade for performance i mainly play CSGO
My mobo tram speed are 2133mhz and i was thinking to upgrade my mobo to z270 for 3200 mhz speeds and upgrade my ram to 2x8gb 3200 but i cant find any mobos the only mobos z270 that i can find are from china +150 euro
What is your advice guys ?
THANK YOU IN ADVANCE!
Although RAM speeds do matter it is not that big of a difference with these older Intel’s. CS GO performance is very cpu dependent and can use up to 4 threads. Just dropping a 7700k into your motherboard will give you a cpu with 25% higher boost speeds and 8 threads instead of 4. Although CS GO only uses 4 threads which your 6500 has it is sharing them with Windows and every other program running in the background. Dropping in a 7700k is going to make a much bigger difference than a RAM upgrade.
The only problem is the 7700k is generally overpriced for the level of performance it gives and is similar to a modern i3 (4 core 8 threads). You have to seriously consider a cpu, RAM, motherboard upgrade to a modern platform. For example a...
I5 6500
Gb b150 mobo
Rx580 8gb
What country are you located and what is your budget?
Reactions: DeMo5h5
I am located at cyprus europe but i order from computer universe or eu shops i dont have a specific budget i will hear the advice and i will see if it worth to upgrade or buy amd mobo and cpu , i am just trying to push it little more until the prices goes back to normal to build q new pc
Reactions: Why_Me
The only problem is the 7700k is generally overpriced for the level of performance it gives and is similar to a modern i3 (4 core 8 threads). You have to seriously consider a cpu, RAM, motherboard upgrade to a modern platform. For example a B550 motherboard, 5600X and 3600mhz 2x8gb.
Reactions: DeMo5h5
Here's a few options to look at that won't break the bank.
i5 10400F build
https://www.computeruniverse.net/en/p/90825402
ASRock B560M PRO4 87,90 €
https://www.computeruniverse.net/en/p/90801904
Intel Core i5-10400F 134,20 €
https://www.computeruniverse.net/en/p/90800899
be quiet! Pure Rock 2 27,65 €
or ...
https://www.computeruniverse.net/en/p/90740986
Cooler Master Hyper 212 Black Edition 28,74 €
https://www.computeruniverse.net/en/p/90792654
Crucial Ballistix Black 16GB (2x8GB) DDR4 3200Mhz CL16 73,89 €
i5 11400F build
https://www.computeruniverse.net/en/p/90826436
MSI MAG B560M BAZOOKA 104,12 €
https://www.computeruniverse.net/en/p/90829359
Intel Core i5-11400F 164,12 €
https://www.computeruniverse.net/en/p/90747470
Arctic Freezer 34 eSports DUO 30,30 €
or ...
https://www.computeruniverse.net/en/p/90793878
be quiet! Shadow Rock 3 37,77 €
Reviews of those cpu's with benchmarks.
https://www.guru3d.com/articles-pages/intel-core-i5-11400f-processor-review,1.html
https://www.techpowerup.com/review/intel-core-i5-11400f/
Reactions: DeMo5h5
Thabk you very kuch for your time
I make a quick build following your advice
16gb ram 3200 2x8gb 75 euro
Amd ryzen 5 5600x 275 euro
Msi mpg b550 gaming olus 120 euro
Adata xpg gammix s11 pro 1TB 126 euro
Total 620 euro
Or
I3 10100f 85 euro
Asrock steel legend z590 200 euro
Ram 16gb 2x8gb 75 euro
Adata xpg gammix s11 pro 1TB 126 EURO
TOTAL 520 euro
Which one is better ?
i5 10400F build
or ...
i5 11400F build
or ...
Yhank you very much for your time and your help
Reactions: Why_Me
Total 620 euro
Or
I3 10100f 85 euro
TOTAL 520 euro
You want 3600Mhz RAM for Ryzen cpu's and the Intel set up is a mess. I've never seen an i3 recommended for a gaming build and an i3 paired with a Z590 board is crazy. Z590 boards are meant for unlocked 11 gen. cpu's.
This build trades blows with the 5600x and does it for cheaper.
https://www.computeruniverse.net/en/p/90744877
ADATA SX6000 Pro M.2 NVME PCIe Gen3 x4 1TB SSD 71,42 €
Total: 443,85 €
A better look at that board.
https://www.msi.com/Motherboard/MAG-B560M-BAZOOKA
Reactions: DeMo5h5
Total: 443,85 €
thank you for give me this build advince but is 100 euro more
https://prnt.sc/1j3v6zy
Reactions: Why_Me
