jenslbelkhir Prominent Jan 2, 2018 13 0 510 Jan 11, 2018 #1 I switched from 1080 ti Gigabyte to Asus Strix. do I need to DDU the drivers?
Solution nitinvaid20 Jan 11, 2018 jenslbelkhir : I switched from 1080 ti Gigabyte to Asus Strix. do I need to DDU the drivers? Nope after installing the new GPU the system may ask you to reboot thats it
K krells Distinguished Nov 10, 2014 1,242 2 19,965 Jan 11, 2018 #2 No, the drivers are the same. Upvote 0 Downvote
nitinvaid20 Splendid Jan 3, 2013 2,708 1 21,965 Jan 11, 2018 Solution #3 jenslbelkhir : I switched from 1080 ti Gigabyte to Asus Strix. do I need to DDU the drivers? Nope after installing the new GPU the system may ask you to reboot thats it Upvote 0 Downvote Solution
A aquielisunari Judicious Mar 31, 2011 6,499 14 33,015 Jan 11, 2018 #4 jenslbelkhir : I switched from 1080 ti Gigabyte to Asus Strix. do I need to DDU the drivers? nitinvaid20 : jenslbelkhir : I switched from 1080 ti Gigabyte to Asus Strix. do I need to DDU the drivers? Nope after installing the new GPU the system may ask you to reboot thats it Agreed. I went with EVGA's Hybrid 1080 Ti. The Strix's max temp 73C http://www.tomshardware.com/reviews/asus-rog-strix-geforce-gtx-1080-ti-oc,5225.html The Hybrid's max temp 46C https://overclock3d.net/reviews/gpu_displays/evga_gtx_1080_ti_ftw3_hybrid_review/16 As far as performance is concerned they will all be within 1 or 2% of each otehr so the decision was based on other factors. It's also relatively quiet. Upvote 0 Downvote
