[SOLVED] I wana upgrade my gpu (1080) to a 3070 but im not sure if i need any change in my cooling or system/ psu
Jan 12, 2021
15
Hi! with the recent release of the new rtx 30 series i decided to upgrade my gpu gtx 1080 to a 3070 but im not sure if i need watercooling
my case is a nzxt h510 and i use the default cooling in it which worked out pretty well soo far for my 1080
and i have a crossair vs650 white psu also unsure if i would need a better one
And i might upgrade my mother board what motherboards would u guys suggest for i7 9700k + rtx 3070 and i have 2x 8gb ddr4 ram (16gb)
Thanks for all your responses and help!
The Corsair VS line are OK for a low end systems.
For the i7 9700k + rtx 3070 combo you need something in the line of a Corsair RM /HX/ TX series.
Which motherboard do you have?
I think you will need a stronger PSU for an RTX 3070. The Ampere cards seem to be hard on PSUs and the one you have isn't a good one.
What is the reason for wanting to change motherboard? I don't really see the benefit if the one you have is working ok.
Asus Intel PRIME B360M-A s1151
this is it and which psu would you recommend from the rm/hx/tx series
Corsair rm650 would this be enough?
because i dont know if the 3070 would be compatible w my motherboard
