[SOLVED] I want help for a custom build
JIANNY
Commendable
Feb 4, 2021
25
Hey!i want to make my build very silent!i have a gtx1050ti Cerberus edition from Asus.Yeah warranty expired.I want a gpu cooler with fans and it should be very very silent.Thank YOU!
(i replaced most of the fans with premium ones like:Arctic Bionix P120/P140)
Anything with moving parts can never be truly silent.
Has one of the graphics card fans failed, or are you looking to replace them?
What is the make/model of the rest of your parts?
Particularly the case, cpu cooler and psu.
Is the graphics card currently the major source of noise?
Fan speed on a graphics card can be controlled, if that is what is needed.
GTX1050ti is not a hot chip so minimal cooling is needed.
the psw fan is changed
the cpu cooler is a Arctic 34 sports Duo
and the last thing the Gpu will be modified.
i put some oil in the fans,it helped but for a little bit of time (1-2 weeks)
just to replace them
You can always try to custom water cool it for cheap(50$)
Look for a Universal GPU block there plenty on Aliexpress that go for around 17$ or you can get a complete loop combo for about 80$!
Though It's up to you!
I'd personally just get a noctua u12s heatsink and install it to the gpu board directly since the gtx 1050 isn't that hard to cool!
