[SOLVED] I wet my components with water. What should i do?
johanzy
33
Hey as the title says I wet my components with water. What should I do?
EDIT: Everything worked fine after 24h! Thanks for the help!
Turn it off and pull all of your components out. Let them dry for 24-48hours. Placing a fan on them or placing the components over a (not too hot) vent in your house can help to dry them. If the pc was off when it happened the damage may have been minimised. Inspect the components for damage before putting them back in and trying to start the pc.
