You would not be able to reuse your current ram. 8gb is still sufficient for gaming. The graphics card is already factory overclocked, and as it doesn't have external power connection, I wouldn't expect it to go much higher. Current gen hardware, and AMD's Ryzen are designed for DDR4. If you do want 16gb ram, then this would be what you would be looking for price.
What is the make/model of that power supply? Wattage means nothing, if it isn't a quality unit. Your motherboard model matters, for what CPU you can upgrade to, without changing it out.
the make is corsair 600w 80 plus bronze certified
the mobo is a fm2 but would like to switch to an i5
Not a great unit, but not so bad that it would damage other hardware. Problem with going with an i5, would be that you would be stuck with a weak graphics card still. This is a little over, but would be far superior, to what you have, and give you an upgrade path. Another option would be to save up more, and wait for AMD Ryzen to release.
would it be better to have the 8gb ram more or just 8gb as i already have 8gb ram installed in my pc
also would i be able to overclock the graphics card
