Question I will really appreciate Any help possible
Jul 28, 2023
I builded my first pc yesterday specs ryzen 5 5700x with a b550 a-pro mother board and I tried running it but from all the sudden I find out a white light flashed in the mother board and next to it , it’s written Cpu , and another thing is that I couldn’t shutdown the pc using the power button from the case , . so I had use the one that attached to the psi ,and today when I got the gpu , and plugged it in , there was no output and the fans on the gpu doesnt works I tried flashing bios using a usb drive , and yet not result , I removed the cmos too for 5 minutes and plug it back no result the same cpu light keep lighting , so I removed the cpu and plug it back still no result ? I will really appreciate any help possible
check your bios version for 7c56va9 for this cpu and made sure not bent pins on it ram in system and gpu in ,
How so ?? Do I need to remove ram and other when installing this version of bios,updated I had installed before the latest versions of the bios and now I installed the version that you mentioned but after a bit of time the red button that indicate the bios installations freezed???
Definitely flash update BIOS to the latest, but it can be tricky. Watch a few videos of "how it's done" on YouTube. This is a good one to watch, even though a different MSI B550 board they all work similarly.
View: https://www.youtube.com/watch?v=mwyQ0Sfz_aw
Reactions: Roland Of Gilead
Yet. Nothing worked… I tried basically every possibility and still no result . You got any alterations solution?
A fairly complete new-build checklist:
It also helps to remove all parts from the case to bench-test it with the motherboard sitting on it's cardboard box when it's a complete new build.
About the only sure-fire way to isolate defective components is to swap in known good parts. Do it one item at a time. Otherwise, it's pretty much guessing based on "most likely to be DOA".
Last: include complete system specs so people know how to make suggestions. That means make and model of all parts: motherboard, CPU, memory, GPU, PSU, CPU cooler, also case and fan arrangement if there's a thermal problem.
