i would like to talk about my experiment with two different ram speed in same machine, 2666 and 3000 Mhz
Aug 27, 2018
so about 2 months ago i got a used gaming pc and the ram was corsair vengeance 8gb dual channel 2666 Mhz, it was so low that one time i got system error that says "Out of memory" so i started looking for an extra 8gb like the one i have but no luck finding it in my area, i only could find 2400 and 3000 Mhz, so i got 3000 Mhz and stared to install it, at first i did't get any luck at installing it so i had to rearrange the ram channels, the 3000 in first slot and the dual in the 2nd and 4th, it was working fine but it 2123 Mhz, so i increase the speed to 2666 , most of the games wouldn't even load so i stared searching and i found that i had to increase the voltage, it was it 1.2V, so i increased the voltage to 1.3V and i worked like a charm , iv been using it from about a month and i hadn't had crashing or anything."i did not modify the timings"
Operating System
Windows 10 Pro 64-bit
CPU
AMD Ryzen 5 1600
14nm Technology
RAM
16.0GB Dual-Channel Unknown @ 1330MHz (16-18-19-44)
Motherboard
ASUSTeK COMPUTER INC. PRIME B350-PLUS (AM4)
Graphics
4095MB NVIDIA GeForce GTX 1080 (ASUStek Computer Inc)
Storage
931GB Seagate ST1000DM010-2EP102 (SATA )
POWER SUPPLY
500 watt (FSP)
and these are the specs of RAM:
Type Unknown
Size 16384 MBytes
Channels # Dual
DRAM Frequency 1330.2 MHz
CAS# Latency (CL) 16 clocks
RAS# to CAS# Delay (tRCD) 18 clocks
RAS# Precharge (tRP) 19 clocks
Cycle Time (tRAS) 44 clocks
Bank Cycle Time (tRC) 63 clocks
Command Rate (CR) T1
That's great, that you were able to get them to play nice with each other.
I wish they make RAM with a "better handshake" when using unmatched modules.
I imagine it that will be something like this:
Ram 1: Hey there...
Ram 2: Hi.....so it looks like we're going to be...
Ram 1: Dual Channel neighbors. I could go as fast as 3000MHz.
Ram 2: Awesome, but I could just hit 2400MHz
Ram 1: No problem I could run at little slower to match your speed.
System boots into BIOS.
Ram 1: Hey there...
