[SOLVED] I5 11600k temps
Oct 31, 2021
Hi guys, I just finished my PC upgrade.
I got i5 11600k with RTX 3070ti.
The temp of GPU while playing on ultra is around 65-67c.
The CPU can get roughly up to 60-75C while gaiming BF2042 or Warzone (other games make my temp go between 50-60C).
On idle my temps are roughly between 27-32C
Are these temps ok? Or should i be concerned? Im asking as i havent done any upgrades in 8 years, im suuuper excited i can play any game now, and obviously i dont want any nasty surprises long term.
My CPU cooler is Corsair H70 which is roughly 6-8 years old.
Also, would adding a fan on the side panel help? (My pc case is antec 1200, i have a slot for a fan that would blow additional air on the gpu).
I would consider those temps to be well within normal range.
Just make sure to regularly de-dust the fans and dust filters. I removed a front panel dust filter (the foam type) to improve air flow as they can be very restrictive.
