Hello,
I just finish putting my build together last nite. Upgraded harddrive today and installed win 7.
I got the Asrock board alot have been recamending and i got that Hyper cooler also.
Atm i got both sides off while i finish up tying some of the wires up and installing window updates and all the good stuff. I got 8gigs of Rip mem, and gtx 550 ti.
When i check the Asrock program that watches the cpu , mb temp and volts . my Cpu is sitting at around 34c and 91f give or take 2 deg. same for MB.
But when i touch the Cpu cooler/fan its cold to the touch so is everything else in the case and the are. My room stays around 68 to 70deg.
i was wondering if this was normal or should i buy some better paste to put on it. Any help is apreciate it dont want to burn my CPU before i get to play any games. Thanks.
