Rije159 :
What's the acceptable stable heat levels for the i5 750?
From Intel's
Processor Spec Finder -
http://processorfinder.intel.com/details.aspx?sSpec=SLBLC
Vcore Max 1.4v
Tcase Max (CPU temperature) 73c
Tjunction (Core temperature) 78c
From the
Core i7 and Core 2 Temperature Guide -
http://www.tomshardware.com/forum/221745-29-sticky-core-core-temperature-guide
Section 1: Introduction
Core i and Core 2 processors have
2 different types of temperature sensors; a CPU case (not computer case) Thermal Diode centered under the Cores, and
Digital
Thermal
Sensors located on each Core. The case Thermal Diode measures
Tcase (
Temperature
case), which is CPU temperature, and the
Digital
Thermal
Sensors measure
Tjunction (
Temperature
junction), which is Core temperature. Since these sensors measure
2 distinct thermal levels, there is a
5c temperature difference between them, which is
Tcase to
Tjunction Gradient. Core i7’s / i5’s and Core 2 Quad’s have
1 Tcase and
4 Tjunction sensors, while Core 2 Duo's have
1 Tcase and
2 Tjunction sensors ...
... The monitoring utilities provided by motherboard manufacturers monitor CPU temperature, while some popular freeware utilities monitor Core temperatures ... Real Temp ... is recommended for users interested in monitoring Core temperatures only ... SpeedFan monitors
Tcase (CPU temperature)
and Tjunction (Core temperature) ...
The thermal specification which is shown in Intel's Processor Spec Finder is Tcase Max (CPU) NOT Tjunction (Core), which is a very common misconception among most enthusiasts. Since there's a 5c gradient between the CPU sensor and the Core sensors, (shown in the following Intel document) -
http://arxiv.org/ftp/arxiv/papers/0709/0709.1861.pdf - just add 5c to the value shown in the Spec Finder to find the corresponding Core temperature, which is 78c for the Core i5 750.
Intel's second and frequently misunderstood thermal specification, Tjunction Max, (100c for all Core i variants) applies to overtemp protection such as Throttle and Shutdown, so you don't toast your transistors. As such, any i5 Core temperatures which exceed 78c should be considered "overtemp". Further, when specifications are exceeded, then premature processor degradation (longevity) becomes a factor that should be considered, which is explained in the following AnandTech article -
http://anandtech.com/cpuchipsets/intel/showdoc.aspx?i=3251&p=6
Hope this helps,
Comp
