I5 760 Review and Advice
WTFO
63
Approximate Purchase Date:Gadget Monday
Budget Range:~1500 duckies current build cost ~Subtotal: $1,245.89
System Usage from Most to Least Important: Gaming/downloading/photoshop/streaming/music/making my breakfast
Parts Not Required: I require all parts
Supply Make & Model If Re-using**Preferred Website(s) for Parts:newegg
Country of Origin:US
Parts Preferences:Intel
Overclocking: Probably
SLI or Crossfire: Maybe later
Monitor Resolution: 1920x1080
Additional Comments: I like toast.... but who doesnt
COOLER MASTER RC-692-KKN2 CM690 II Advanced Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216
ASUS P7P55D-E Pro LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131621
GIGABYTE GV-N460OC-1GI GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125333
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
Intel Core i5-760 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core Desktop Processor BX80605I5760
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115067
A-DATA Gaming Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600GB2G9-2G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211409
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
2x Acer G235HAbd 23'' 5ms 1920x1080 WideScreen LCD monitor 300 cd/m2 1000:1
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009266
LITE-ON Black 24X DVD+R 8X DVD+RW 8X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Writer
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106334
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long life sleeve CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
** This will be my first build and i just would like to know from the more tech sauvy people if this is a good build that will still be relevant a few years down the road. Any upgrades or trades for better price/performance are greatly appreciated. thanks for the help.
wait for Jan 5th sandy bridge.
"Dragon Age on the other hand shows an 11.6% gain vs. the i5 760 and equal performance to the Core i7 880. Given that the i5 2400 is slated to be cheaper than the i5 760, I can't complain."
or buy everything but the Mobo,CPU, and cooler when its cheap then just buy the CPU and mobo when they are released.. thats what I'm doing.
