M murphyjack1126 Jan 9, 2019 2 0 10 Jan 10, 2019 #1 So I just ordered an i5-9600k and wanted to know what cooler to pair with it? I have a 212 evo already and a kraken m22 but I'm almost positive that wont be enough. Could I go with a 240mm? Or should go the whole 360mm?
Solution Gam3r01 Jan 10, 2019 At stock either of those two coolers should keep it cool enough. If you plan to OC, you should go with a 240/280mm rad or 140mm air cooler.
Gam3r01 Titan Jan 12, 2013 25,414 976 115,440 Jan 10, 2019 Solution #2 At stock either of those two coolers should keep it cool enough. If you plan to OC, you should go with a 240/280mm rad or 140mm air cooler. Upvote 0 Downvote Solution
WildCard999 Titan Moderator Jul 18, 2014 21,785 1,937 93,640 Jan 10, 2019 #3 I'd think the M22 would be be sufficient for a decent overclock due to the soldered tim. As for the EVO 212 I would only run it at stock. Upvote 0 Downvote
