Question i7-14700k running too hot with Peerless Assassin when rendering photos?
EstimatedEyes
21
Firing up my new build, and hitting temps around 27-32 most of the time, except when rendering photos in Lightroom (building 1:1 or Standard previews), when temps are consistently in the 70s and 80s but occasionaly spiking into the high 90s accoring to the max column in Core Temp which has me a bit concerned. I need to render quite a few over the next few weeks to rebuild my catalog previews, and wondering if this is something to worry about.
Using a Thermalright Peerless Assassin 120 SE with the i7-14700k on a Gigabyte Z790 Aorus Elite AX ICE 1.0 in a Fractal Pop Air case. Also:; Corsair Vengeance DDR5 5200 64 GB (2x32), MSI Ventus GeForce RTX 4060 Ti 8GB, Corsair 850W PSU. I did not apply any OC settings (but idk if the Gigabyte board did by default).
Don't want to go to liquid cooling since this isn't a gaming rig and rendering will slow down once I get the catalog rebuilt and temps are otherwise solid.
Thanks in advance of any suggestions.
That's not hot for that processor according to Intel. You can limit the voltage down some in BIOS if the temps scare you.
Since those processors are apparently having issues I would limit the voltage anyhow.
What do you have the pl1/pl2 set to. It seems the cooler is keeping up with the temps. As long as you do not see spikes to 100c it will not reduce the clocks.
In some ways you would water cool a NON gaming machine. Most gaming only uses limited cores which greatly reduces the power/heat being used.
That peerless cooler has been tested on 13700k even with the pl1/pl2 set to 253/253 which is a overclock and it still does not thermal throttle. If you set it to 4095/4095 then you need to water cool it and it still likely will thermal throttle.
You may also want to check your fan curves sometimes you can get a temperature spike because the fan curve didn't spin the fans up quickly enough as the load increased. Maybe set the fans at 100% all the time and see if it looks any different.
Lightroom preview generation (usually after image import) definitely maxes out the CPU. Consider limiting PL1 in the BIOS to around 150-175W - and perhaps even less - if you have a very large library to import/rebuild and you don’t want to mess with your current setup.
If it’s not hitting tjmax throttling in HWInfo then you’re probably fine with no changes. But @Zerk2012 comment about voltages is worth addressing.
Your temperatures are nominal.
The processor is designed to run up to 100c.
Actually rendering puts more heat load than gaming because it uses more processing threads.
First of all, update your bios.
Motherboard makers were too aggressive with voltages that exceeded Intel specs to improve performance
Motherboard makers have since released bios updates to limit the voltages by default.
Your cooler is a very good one for what it is.
But replacing with a noctua cooler with 140mm fans will do better.
Noctua NH-D15 or NH-D15s would do better,
For the ultimate, see if you can't find a NH-D15 G2:
Thanks for the responses. I previously updated BIOS to the most current version (F5e), which I think is supposed to set it back to the Intel power defaults. I just checked BIOS and the power limits are all set to "Auto" (with no numerical indication of what that is). The overall power limit is showing as 253W. I did not manually set or make changes to the voltage or power limits. Only changes I made to BIOS were to enable XMP, high bandwith and low latency for the memory.
The one thing I did that appears to have knocked about 5 degrees off the temps is to remove the magnetic filter mesh that sits above the top fan vents on the top of the case (Fractal Pop Air). No fans installed there, but it does seem to have helped the airflow while rendering. I have generated previews for around 30,000 images and temps seem to be staying in the 60s and 70s for the most part, though still spiking to the 90s per CPU Temp.
Probably just a good idea to buy 2 140mm fans to exhaust more heat through the top panel faster than just relying on a single exhaust fan. Your CPU cooler loses to the Noctua NHD15v2 by less than 2 degrees According to tests ran by Gamers Nexus, so I wouldn't go wasting $150 on a new CPU air cooler. You may want to read tat Verge Article where they finally actually got Intel to go on record at least giving us some more info, although it's not exactly super convincing that they aren't still not telling us everythng.
CPU%20Cooler%20Benchmark%20_%203950X%20OC%20~198W%20_%2035dBA%20Noise-Normalized%20_%20GamersNexus%20%28SUPPORT_donate_%20store.gamersnexus.net%29_3.png.webp
