Question i7 6700 + gtx 1080 far cry 3 ubisoft problem unable to stay over 60fps
Robert319
Commendable
Nov 4, 2016
44
i an having problem with my configuration and far cry 3. I am using all settings maxed out at 1080p dx11 with vsync turned off. When i started new game i ran fraps and played till i got off the first tower.I haven't played with nvidia control panel so the settings are default. The results were:
Frames, Time (ms), Min, Max, Avg
63326, 955281, 22, 143, 66.290
there was also a lot of frame tearing
my pc spec:
gtx 1080
i7 6700
750w psu
16gb ram
Newtonius
Upstanding
Sep 25, 2019
391
73
290
24
Try reinstalling the Nvidia drivers. Also what is your motherboard? That CPU, while not the worst, isn't exactly the best to pair with a 1080.
Phaaze88
Herald
1)If fps didn't change even after lowering settings, that usually indicates a cpu limitation...
-Cpu temps are good?
-1 or 2 sticks of ram?
-Done any virus scans lately? This one tends to catch things that usually slip past the AVs: https://downloads.malwarebytes.com/file/adwcleaner
2)You need to enable fast sync or v-sync - or cap the in game fps to 60 - in Nvidia Control Panel. That screen tearing is from your in-game fps exceeding what your monitor is capable of displaying.
Robert319
Commendable
Nov 4, 2016
44
cpu temps don's exceed 70c, i have 2x8gb 2400mhz g.skill ram modules. I have done that scan and it found 3 files witch i deleted.
