So i recently got a i7 7700k.
You might say that i have a bad cooler or not much paste on.
I have a 360mm aio that runs at 2k rpms, It was used in my old friends pc, Same specs btw.
I also have a good amount of paste on it, Idle at 30c 4.6ghz.
But It goes up to 40-50 at 10-40% load, And over 40 its at 60-70c.
I have stress tested the cpu and it cant go any higher than 70c at 100% load, (Used msi kombustor cpu test)
Also regular aio placement (Front of the case, Tubes on the top.
Case: Eclipse g360a.
I have intake in front whit radiator
Exhaust rear(1) and on top(2) (Good airflow).
Aio is set to max in the bios.
Its not cause the overclock, Does the same at 4.2ghz to 4.8ghz. Help im 13 and im not super good at pcs.
Thermal throttle is on in the bios.
