[SOLVED] i79700k Temp and Voltage.
Mar 13, 2019
Hi everyone. I’m new at pc world so I need to now if these values are all right.
i7 9700k running at 4,6Ghz with voltage at 1,260V and temp at 25 C.
This is my configuration
Z390 Aorus Elite
16GB Corsair vengeance pro @ 3600
240GB Corsair M2 MP510
Samsung Evo 850 500GB
ID ZoomFlow 240 WCooling
Gigabyte 2080ti Gaming OC
Gigabyte G750H PSU
Thanks!!
seems fine if you are stable, 25c at idle doesn't mean a whole lot, it's your temps at load that you need to keep an eye on. as long as you can keeps your numbers under 70-75c you won't have an issue
Reactions: PAPM
Thanks I was worried about the cpu and the voltage. When I’m playing apex it gets 58-60C but know I know it’s ok.
