Question I9-9900K cooling solutions.
Jonatron5
160
Thinking about running a corsair hydro Series™ H100i RGB PLATINUM SE 240mm
Liquid cooler. And just wanted to check with the good people of this forum, if its suffeicent to cool my cpu?
Also corsair has some amazing rgbs
Actually, I9-9900k is a hot CPU. 95°C is normal for the stock cooler. but if you use this AIO liquid cooler, you can achieve around 65°c without OC. or about 80°c with MCE. I just watched some videos on YouTube about what I said. anyway, It's enough for I9-9900k if you don't want to have under 60°c temps. again, this CPU temp is higher than other CPUs and don't reduce it's life cycle.
