G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hello
Due to video editing, I have four HDDs running on the two IDE channels on my
ASUS P4S8X motherboard. I installed a SIIG UltraATA 133 PCI controller board to
accomodate my ZIP and DVD Burner. This worked well.
Sadly my DVD Burner died and I purchased a replacement, which refused to run
well on the IDE controller, software not picking it up as a DVD drive. Having
moved the HDD arrangement to accomodate I run into several problems:
1. UltraATA board will not allow HD to be connected under any configuration
other than the Boot HDD being added to the board. It recognises them, but will
not boot to Windows.
2. When the HDDs are configured to boot to windows two of the four perform with
sluggishness that eventually hangs the computer. Video is jerky out of synch
and then freezes etc. Tranfer of files takes an eternity.
I hve tried every configuration with the drives Master, Slave, Cable Select and
have mixed the drives to find a workable match to no avail. I have tried
without the controller card and adding a hard disk at a time etc.
Any suggestions?
Steve
Hello
Any suggestions?
Steve
