Short version: How do I find what the ideal operating temperature is for a given motherboard?
Long version: I built my first PC last July (spec list below). While I'm still very new to the world of PC building, I had done enough research to understand the importance of a good cooling solution. As I was trying to keep the price for the system down, I chose to invest in a set of Arctic PWM case fans and an Arctic CPU cooler. I haven't had any issues regarding the performance of the hardware ever since I first turned this PC on. Now, however, I'm starting to wonder if I need to upgrade my cooling solution. My chief concern is whether my motherboard is running hot and what steps I should take to try bringing the temperature down. As far as I've been able to confirm, all the temperatures I've noted (with the use of CPUID Hardware Monitor) have been within the operating ranges of the components. How concerned should I be? At what point should I seriously consider upgrading? What should I keep an eye out for?
Spec list:
Spec list:
- Intel i5 9600k
- Gigabyte Z390 UD
- Corsair Vengeance LPX 2666Mhz (4 x 8GB)
- GTX 1060 6GB
- Seagate 650-watt PSU
- Arctic F12 PWM case fans (x 4)
- Arctic Freezer 12
