[SOLVED] Ideal use of H115i fans in iCUE 465X case
Aug 10, 2020
Hi everyone,
I'm planning on assembling an H115i watercooling in a iCUE 465X case.
The case is only meant to accept the radiator on front, if I understand well its specs.
The case comes with 3 front fans (120) for intake.
I'll be adding another 120 on the back to pull air.
But the H115i comes himself with two 140 fans, wich I understand are to be placed on the 280 radiator.
My question is : should I mount the radiator fans... on the radiator ? Or just one of the two 140, and place the other on top of the case to add out-take? Or mount neither of the 140 ?
I'm new to watercooling and I can't find out if my radiatior will need to be sandwiched between the 3 intakes of the case and its own two 140 fans or better left alone with only the 3 front fans, discading the watercooling ones ?
Thank you very much in advance to anyone who could answer me !
PS : (full config if necessary : it will run with a Ryzen 5 3600 and a 2060 RTX, as well as 4x8Go Ram and an M2 SSD)
No need to add another fan - waste of money. The chassis is preinstalled with 3x LL120 fans in front, so here's what you'll do:
Remove the 3x LL120s - they will not fit together with the H115i and its fans. Install 2 of them top exhaust, and the remaining fan as rear exhaust.
The H115i radiator is to be installed in the front, with the fans behind it pulling air through. Done.
Reactions: Elyss
Woh that... is... actually very smart...! Thanks a lot, that makes so much sense !
So to confirm, I would have the two 140 on front (lighting outside the case), intaking air into the radiator behind them, then the three 120 pulling air out on back and top ?
No, the 2x 140 would be behind the radiator, pulling air through from behind. This gives the fans more 'breathing room' from the front panel, as well as providing a more direct path for air to the gpu.
Might not be as aesthetically pleasant to you, but for cooling performance, it's a little better than the fans pushing air through the rad.
The rest is correct.
All right then ! I'll go for that ! ^_^ Thank you a lot for you advices !
