Hello,
I paired my Ryzen 7 5700g up with Arctic Cooling Liquid Freezer 360 AIO cooler, because I wanted as quiet system as possible. Silent is something very important for me and I went with that AIO.
Problems started a few days after I booted my system for a first time - I didn't overclocked or auto-boosted my CPU at all, it's holding at base 3.6GHz clock, but idle temps with ~10% usage, with no apps/games running, are 50 C... At that temperatures, my AIO and system fans are running at about 1000RPM (Smart mode is turned on in bios, I even lowered RPMs a bit down because this CPU doesn't really need 360 for a base clock to stay cool), but still, it's very loud and temperatures are crazy!
Case is clean as my tongue, it doesn't have any dust on radiator/fans or something like that. Thermal paste is Arctic's MX4, applied like everyone would, not too much but it's also not lacking.
I also tried stress testing my CPU, after 15 minutes, max temp on 100% load was 61 C, and max RPMs on the fans were around 1500RPM, just a few hundres higher than idle ones..
If you know what it can be, please help me down below, this noise is so annoying and I dunno how 360mm AIO needs 1000RPM on all three fans to cool base clock Ryzen 7 5700g on idle?
EDIT:
Some guy had a similar problem, but his CPU was boosted to 4.7GHz clock, mine is, I'm repeating again, on base clock.
EDIT:
