Question Idle temperature 50 C and Full Load Temperature 60 C on Ryzen 7 5700g
Nov 1, 2021
16
Hello,
I paired my Ryzen 7 5700g up with Arctic Cooling Liquid Freezer 360 AIO cooler, because I wanted as quiet system as possible. Silent is something very important for me and I went with that AIO.
Problems started a few days after I booted my system for a first time - I didn't overclocked or auto-boosted my CPU at all, it's holding at base 3.6GHz clock, but idle temps with ~10% usage, with no apps/games running, are 50 C... At that temperatures, my AIO and system fans are running at about 1000RPM (Smart mode is turned on in bios, I even lowered RPMs a bit down because this CPU doesn't really need 360 for a base clock to stay cool), but still, it's very loud and temperatures are crazy!
Case is clean as my tongue, it doesn't have any dust on radiator/fans or something like that. Thermal paste is Arctic's MX4, applied like everyone would, not too much but it's also not lacking.
I also tried stress testing my CPU, after 15 minutes, max temp on 100% load was 61 C, and max RPMs on the fans were around 1500RPM, just a few hundres higher than idle ones..
If you know what it can be, please help me down below, this noise is so annoying and I dunno how 360mm AIO needs 1000RPM on all three fans to cool base clock Ryzen 7 5700g on idle?
EDIT:
Some guy had a similar problem, but his CPU was boosted to 4.7GHz clock, mine is, I'm repeating again, on base clock.
Yep, under load, it's climbing all the way up to 4.6GHz, but the RPM too.. Do you maybe know, how high with the temperatures can I leave my 360 AIO on 800-900RPM? Because whenever I do something a little bit more demand than Chrome browsing, RPMs jump to 950-1000RPMs (Which sounds quiet but it actually annoyes me, because I'm not wearing headset and the PC is distanced from my ears like less than 20 centimeters..). So, can I set my fans in BIOS to run 700-800RPM even at 60C? Would that be fine?
Yeah, I'm just concerned about those idle temps because I don't want to shorten CPU's life, I don't know if 50-55C can do it on 5000 series though?
I set my fan profile to be dead quiet until the CPU temp gets to about 75C, then only slowly rise it until about 90C. ALWAYS run your AIO pump at full speed because you're using water to cool the CPU. So long as it's flowing it's cooling the CPU even if the fans are off, the faster it flows the better it cools. Unlike the metal of air coolers it takes a very long time (hours) for the water in a 360mm AIO to heat up.
50-55C is actually quite cool for modern CPU's so you've nothing to worry about.
How do I actually know if it's running 100%? In BIOS, it just gives me control over fans (System1 and PUMP1), is that it or?
Thank you very much for all the informations. I'll definently implement those settings in my BIOS too.
You should check the mounting pressure of your cooler on the 5700g. Should also check the bios and see if you've plug the pump into the correct header. There tends to be a header for cpu fan/water pump. My 5700g, with a 140mm aio idles at 28-33c. It hits a max of about 68c with the fan at about 60% rpm(1300rpm). Sounds like your pump might be plugged into the wrong header, or you haven't gone in bios and switch the controller from a cpu fan to water pump.
