How long have you had that AIO? The pumps break down over time, forcing you to replace the entire unit.
Fan set up is a bit of a mess.
1)The stock cpu cooler fan is set as rear intake - I can't tell what the orientation of the Noctua fan behind it is... it would be a problem if it were exhaust though.
Solution: it needs to be set to either rear or top exhaust - if the unit's pump isn't broken, that is. Also, if you're going to set it as push-pull, have the fans set to move air in the same direction.
2)Top fan is exhaust. No real issue here.
3)The Gpu AIO is front exhaust, but the fan right below it is set to intake... that's recirculating the same old air.
Solution: Flip both of the AIO fans to intake.
4)Bottom fan intake. No issue...
