I'm building a pc. Its my first ever pc build. So i want check that all parts i have picked is compatible with each other.
I believe the CX430 is of the builder series, walk away from it before you drop any money on it.
As to GPU, you PC doesn't give a rip whether you use nVidia or AMD with either an AMD or Intel CPU. (align AMD with AMD if you wish, align Intel with nVidia if you wish, align Intel with AMD if you wish, align AMD with nVidia if you wish... ZERO penalties because of branding.) What makes the difference is the capabilities of each. Note though in one or two years, the 1050Ti will have been replaced with something better and around the same price point (with allowance for inflation.) An iGPU has always been found wanting when it comes to gaming. If you don't game, there's no major need for a dedicated GPU.
Pretty much now days, RAM is RAM...
MERGED QUESTION
Question from Himanshu_1999 : "I'm building a pc. Its my first ever pc build. So i want check that all parts i have picked is compatible with each other."
Pretty much now days, RAM is RAM is RAM. You want DDR4-2400 RAM, no problem, just pick the cheapest. In some instances, don't even worry if the cheaper RAM is faster. it should work at 2400 as well. (worst case scenario is it is guaranteed to work at 2133.)
I assume you are in India?
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor (₹16700.00 @ Amazon India)
Motherboard: Asus STRIX B250F GAMING ATX LGA1151 Motherboard (₹11000.00 @ Amazon India)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2400 Memory (₹4710.87 @ Amazon India)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (₹3589.00 @ Amazon India)
Case: Rosewill STEALTH ATX Mid Tower Case (₹3028.17 @ Amazon India)
Power Supply: SeaSonic EVO Edition 750W 80+ Bronze Certified Fully-Modular ATX Power Supply (₹9300.00 @ Amazon India)
Total: ₹48328.04
Generated by PCPartPicker 2017-05-03 20:45 IST+0530
