I'm buying these parts for gaming pc BUT ARE THEY COMPATIBLE?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
EVGA GeForce GTX 970 ACX 2.0 4GB GDDR5 256bit
Asus Z87 PRO LGA 1150 Motherboard
Kingston HyperX FURY 16GB Kit (2x8GB)
Intel Core i5-4690K Processor 3.5 GHz LGA 1150 BX80646I54690K
Corsair CX Series 850 Watt ATX/EPS Modular 80 PLUS Bronze ATX12V/EPS12V 552 Power Supply CX850M
Corsair Hydro Series Extreme Performance Liquid CPU Cooler H100i
Corsair Obsidian Series 750D Performance Full Tower Case CC-9011035-WW
LG Internal UH12NS30 BD-ROM Blu-ray Optical Drive
Compatible, yes, but.....
The GPU will run in almost anything.
Why that motherboard? If it is modern, the BIOS will be updated so that it will run your CPU, if not, you will need a BIOS update (Which may need another CPU to install it. I would be looking at a Z97 motherboard.
You don't need 850W of PSU unless you plan to SLI, and even then 750 will do with the hardware you have. I'd be looking at a higher-performance PSU, starting with an EVGA B2 - 750, semi-modular.
I would go for cheaper, quieter, easier to use 'big air' over fluid. How much do you need to overclock your CPU? I'm running a good i5-4690K at 4.7Ghz and 1.3V on a RAIJINTEK Pallas.
What speed and latency is your memory. CL10 2400Mhz will improve your performance some.
Here's some of the things I have been doing. http://www.tomshardware.com/forum/id-2719471/4690k-memory-overclocking-project-results.html
