Hi,
I've had my JBL Tune130NC TWS Earbuds for about a year and the past month they started having problems. When they are taken out of the case they initially start on a really low volume and powerful high end with almost no low end, and then after letting them run for about 3min they gradually get louder and start working properly. What would be the cause of this? I had had them run on max for probably too long a time but I was under the impression that they should have some limiter as to how loud or how powerful the low end could get.
Another problem seems to be that when I am commuting home on a bus they start as if to shake in around the shell when the bus hits a little rougher terrain. Are the two connected? Should I just get new earphones?
