I'm not sure if I have a fan on my cpu. Can the cooler be any type of cooler? Also not sure how to upload photos. This is my first time posting in any forum ever.
Defiently not I'm reading on how to upload a photo on hereWell, it would probably look something like this:
Okay what does that mean lol? All I known everytime I start my pc I get a message that pops up saying cpu fan error. Doesn't seem to cause any problems for me just wondering whats that all about. Also backbwhen I got it from someone in 2010 it had a lot of problems and I was cleaning out virus and stuff one day and reset the bios back to default. Idk if I need to have any thing set in the bios or not. My concern was when I play the division 2 my computer gets super hot. Now since I cleaned all the fans out its not as hot but still.That looks like a passive cooler to me.
Probably sooner since the division is have some cpu usage problems just about anybody is running at 100%. I'm looking into upgrading many features. We'll pretty the whole thing considering my mobo is an older one it only uses ddr 3You should probably think about replacing those heat sinks with a proper fan. The more demanding the games get you play, the more problems you will have in the future.
Maybe the fan controller on the motherboard is broken, though, which might have been the reason for the previous owner to put in a passive cooler.
Sooner or later you will burn through your CPU, I am pretty sure.
I am especially curious about the CPU you are running, as passive coolers normally should only be used for 45 Watt CPU and below.What are full specs of your pc?
If I go to the fan on it cuz I was thinking about buying the fan of going to buy for a new set up and just go ahead and install on my old setup how would I take this passive heat cooler or is it just those two towers or it looks like there's some put a piping I don't know that's includedWhat you should do for the time being:
Very carefully unmount those hunks and renew the thermal paste. In a setup like that a proper thermal paste layer is more important than anything and it only costs you around 10 bucks.
After nearly ten years of being there, the old paste is probably hard as concrete and sub-par.
Also I'm using speech to text my badIf I go to the fan on it cuz I was thinking about buying the fan of going to buy for a new set up and just go ahead and install on my old setup how would I take this passive heat cooler or is it just those two towers or it looks like there's some put a piping I don't know that's included
The piping normally vents the hot air from the thermal plate, sitting directly on the cpu, into the heat sinks. It is part of the whole construction, normally and is attached to the heat sinks.If I go to the fan on it cuz I was thinking about buying the fan of going to buy for a new set up and just go ahead and install on my old setup how would I take this passive heat cooler or is it just those two towers or it looks like there's some put a piping I don't know that's included
I'm not home to give exact specs but off the top of my head
Processor : Intel core i7 @2.67gh, 2668mhz 4 cores, 8 logical
Mother board : p6x58D premium
Soket - lga 1366
Chio set Intel x58
33 gb of ram I think may have 20
Ssd 240
Hdd not sure size I have 600gb free space atm I think
Graphics card geforce gtx 970
Psu- 750 w it's either 80 bronze or 80 gold rating
The brand name was thermal so thing I think
I'll get more info when I get back home
Yeah, that's i7-920 - 130W TDP cpu. You don't put that on passive cooling.Processor : Intel core i7 @2.67gh, 2668mhz 4 cores, 8 logical Soket - lga 1366
