Approximate Purchase Date: Tomorrow night
Budget Range: $1250.00
System Usage from Most to Least Important: Gaming, gaming, gaming!
Are you buying a monitor: No
Parts to Upgrade: Need to purchase everything but the Power supply and a heat sync...i have a ZALMAN CNPS9900ALED 120mm 2 Ball Low-noise Blue LED CPU Cooler, which is a cooler master 1000w. I also would like a full ATX tower but have a cooler master one picked out for $160(COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Black Steel ATX Full Tower Computer Case with USB 3.0, Black Interior and Four Fans-1x 230mm front RED LED fan, 1x 140mm rear fan, 1x 230mm top fan, and 1x 230mm side fan), which does NOT need to be deducted from the budget i listed above. I also have a gtx 560ti, but this could be upgraded if need be.
Do you need to buy OS: No
Preferred Website(s) for Parts: Newegg.com
Parts Preferences: I would like all the parts to be very reputable. I use to know computer parts so well and i have put two systems together myself over the past 9 years....however now i cannot seem to find a motherboard that won't confuse me, as i haven't had to mess with bios before.
Overclocking: Whatever is the medium? In terms of being safe, but still having a very very fast cpu.
SLI or Crossfire: if you can find two cards that you don't think will overheat then two would be awesome. If one will do the job nicely for bf3/crysis3 then one works.
Your Monitor Resolution: 1680x1050
Additional Comments:I just don't want to mess with too many things besides drivers and such. I would like to load games exceptionally fast and boot up my computer very very quickly and also maintain 60+ fps in every encounter in bf3 and diablo 3(non resource intensive you would think....but blizzard sucks at coding imo)
And Most Importantly, Why Are You Upgrading: I have a 775 socket mb with ddr2 and a case with no working fans and an 8200 core duo cpu.
