[SOLVED] In need of a USB switch to work with Razer Keyboard and Mouse
SMITH34901
24
I need a USB switch/KVM that are compatible with a Razer Deathadder mouse and a Razer Ornata Chroma keyboard. I can't install any software onto my work laptop so it has to be some kind of switch. I have been looking around but everything I have read says they don't work sometimes. Has anyone had any luck getting one to work with the Razer peripherals?
Thanks!!
Glad to have helped!
you can mark an answer as Best Answer since you are the owner of the thread.
That way, others with similar issue to yours can see it show up as solved. Once you pick the Best Answer, it becomes a SOLVED thread automatically, and is colored green. That's how it's supposed to work around here anyway.
cheers
