In need of a White CPU Cooler fora i5 4440
JimmiGilbi
92
Hi All
As the title says,
for this part build-
http://ca.pcpartpicker.com/p/YNV9zy
Problem is the low clearance of the Corsair air 240 case (window up) (120mm)
Really looking for a cpu cooler that will work for a white build.
Budget not an issue.
Also, I've never really cared too much for cable management but lately I have. I'm looking a white cable set. I've seen a few online but would like input on which to get.
Not exactly familiar with cabling, but the CPU cooler will do good. It's not meant for overclocking, and you can't even overclock with the i5 4440 so you're good to go. It's a slight upgrade from the stock cooler.
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($240.98 @ Newegg Canada)
CPU Cooler: Arctic Cooling Alpine 11 Plus Fluid Dynamic Bearing CPU Cooler ($14.99 @ Memory Express)
Motherboard: Asus H97M-PLUS Micro ATX LGA1150 Motherboard ($129.96 @ DirectCanada)
Memory: Kingston HyperX Fury White 8GB (2 x 4GB) DDR3-1600 Memory ($60.99 @ NCIX)
Storage: Crucial BX100 500GB 2.5" Solid State Drive ($215.98 @ DirectCanada)
Video Card: KFA2 GeForce GTX 980 Ti 6GB Video Card
Case: Corsair Air 240 MicroATX Mid Tower Case ($99.99 @ Memory Express)
Power Supply: Fractal Design Tesla R2 650W 80+ Gold Certified ATX Power Supply
Total: $762.89
Generated by PCPartPicker 2015-08-17 20:47 EDT-0400
If you haven't already bought the parts, here's a better one.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($224.50 @ shopRBC)
Motherboard: Gigabyte GA-H97M-HD3 Micro ATX LGA1150 Motherboard ($98.75 @ Vuugo)
Total: $715.20
Generated by PCPartPicker 2015-08-17 20:50 EDT-0400
I threw in a CPU cooler slightly better than the stock one because you can't overclock with a locked i5 and an H97 board. So no need for a beast cooler unless overclocking.
Hi.
I have the cpu, RAM, case & mobo already. The list I posted, and I should of said, is partly built. My bad.
So, you recommend that cpu cooler?
Any info on cabling?
Thanks and appropriated
