Hello! I was planning on upgrading my rig for better gaming performance and fps. But I am wondering about either or not the Ryzen 5 3600X and GTX 2070 Super is gonna be compatible with my current specs. If not, can you guys help me suggest some better options? I am sort of in a budget.
I am being told to change my motherboard as some are claiming that it won't be compatible but I also find forums that say it will be fine which is making it very confusing for me. That's why I hope you will be able to help me with the build. Here are my current specs :
Casing: Cooler Master Masterbox Lite 3.1 ( Supports only mATX and mITX)
Motherboard: Asus Prime B350M-E (mATX)
CPU: AMD Ryzen 5 1600 Six Core 2.5 GHz
Ram: G.SKILL Ripjaws V Series (8x2)GB 288-Pin DDR4 SDRAM DDR4 2400
GPU: Nvidia GTX 1050 Ti
Hard drive: WD Blue 1TB (2012)
SSD: PNY CS900 120GB
Monitor: (1)Acer KG251Q 240Hz HDMI DP FreeSync and (2) LG 24MK400H-B 75Hz HDMI VGA FreeSync.
PSU: MasterWatt Lite 500W
