So I buyed a new PC, I installed Windows 10, and when it comes to the part when I need to take USB Drive out, I take it and when it reebots it brings me back to te BIOS Setup and I can not do anything. Please help.
what motherboard do you have? Some motherboards have a choice where you can set a priority boot item for 1 startup so PC uses it once and then defaults to default one.
If yours is like this, setting USB to 1st in boot order will mean it doesn't swap to the hdd at 2nd step of the install process and instead goes looking for the USB drive.
If you tell me what motherboard you have, I can go look in manual and see what you need to set.
