Don't see any mention of it in the manual Take a look yourself. https://www.manualslib.com/download/648473/Panasonic-Th-42pz85b.html
You could try changing the audio setting in your sources to PCM and maybe the TV will just pass that through.
If not use the analog audio output instead. Will work just as well in this case.
