Intel Bayfield (ATX 865G); reliable? Prescott too hot?
G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
I've been building PCs for a few years now, and since Socket 7 I have
preferred Intel motherboard chipsets (tho generally not Intel mobos).
I recently moved from generic 865G motherboards to using Intel's
Bayfield, which is a full-ATX based on that chipset.
I've found reliability to be more erratic than I'd previously
considered acceptable for motherboards. A couple of outright
failures, but more often it's been general flakiness (e.g. locking up
at temps other sample boards don't lock up, or locking up at
particular points in the MemTest suite).
Also, usually when a processor core is shrunk, the new chips will run
cooler at a given clock speed. Once again, Prescott has defied the
usual expectations; even the modest Celeron 2.4GHz tends to push what
Bayfield calls "Zone 2" to 42C - 47C, with some Bayfield motherboards
regularly locking up at 42C and others being happy at full temp.
What's been other ppl's mileage on this stuff?
I'm baaaack!
On Mon, 06 Dec 2004 00:45:44 +0200, "cquirke (MVP Win9x)"
Intel's boards aren't really all that different from any other
company, and not really any more reliable either. I don't know about
this particular model, but all companies have the odd board that just
doesn't match up with others.
>usual expectations;
You are forgetting that the Prescott is NOT a core shrink at all, but
rather a major overhaul of the whole chip design. The reason why the
Prescott consumes more power than the Northwood before it is that
Intel more than doubled the number of transistors (from ~55M to
~125M).
On a per-transistor basis, Intel's Prescott shows just as much of a
power consumption drop as previous die shrinks (ie "Willamette" P4 at
180nm to "Northwood" P4 at 130nm), but when you factor in the large
increase in transistor count, it's no surprise that the chip consumes
more power.
Of course, the question that none of us have been able to answer is
why in the heck did Intel more than double the transistor count
without a really noticeable improvement in performance?! But I
digress..
I'm not quite sure where "Zone 2" is in this board, but it sounds like
perhaps your not getting very much airflow through the case? It
doesn't do much good to remove the heat from your processor if that
heat isn't subsequently being moved out of the case.
Tony Hill
hilla <underscore> 20 <at> yahoo <dot> ca
On Mon, 06 Dec 2004 06:53:10 -0500, Tony Hill
What I didn't expect was, *less* reliability. Mobo failures, DoA, or
turning up as baddie on swap testing were very rare before Bayfield,
other than the capacitor failures that is.
>I don't know about this particular model, but all companies have
>the odd board that just doesn't match up with others.
This isn't base on one baddie, but a few over several months.
>>usual expectations;
>~125M).
I know L2 counts a lot for that, but where did the rest go? Usually
they either simplify at a mild performance hit, and/or add
functionalities like new SIMD opcodes. Does HT take up so many
trannies? If so, how does that affect no-HT Celeron? My mileage is
based on Prescott Celeron, which as slightly faster base speed and L2
pushed from 128k to 256k and not much else. In fact, deeper pipelines
are said to lose most of what L2 gains, at current GHz.
Law of Diminishing Returns? Moore predicted double the trannies every
18 months, and it's the extrapolation of others that assume this means
twice the speed. There's only so much you can do by increasing
"processing about processing" - so I expect full multi-CPU dies next.
Exactlty - and neither manual nor board map show where these sensors
are, nor could I find info at Intel's site.
I had to move from one case design that had PSU vertically in front of
CPU, which I suspect created a hot pocket at top of case between the
PSU and CPU assembly. Extra case fans didn't help.
But even with the larger case design that has horizontal PSU above the
mobo, I still see heat issues. As a non-overclocker who generally
uses modest (Celeron) chips with boxed fans that have been fine until
now, I'm surprised to see these sort of heat problems.
I'm baaaack!
On Mon, 06 Dec 2004 20:35:07 +0200, "cquirke (MVP Win9x)"
It may simply be that this model of board is a bad design, not just
one sample of the board. If the problems are one of design, than that
is entirely possible.
>>~125M).
That's the real question now isn't it.. The extra L2 cache counts for
about 30-35M transistors (6 transistors per bit, 9 bits per bit due to
ECC and 512KBytes + some redundancy). Others are just used for
testing and not actually enabled for normal use. Others still were
added for the extra 11 instructions that make up SIMD. A few of them
are also there for the 64-bit EM64T support (present but disabled on
most chips).
In the end though, it still seems like a LOT of extra transistors
given the nearly non-existent performance gains (an occasional
performance loses).
> Does HT take up so many trannies?
Hyperthreading was implemented in Northwood, and while it was slightly
changed in Prescott (including the addition of two new instructions),
it doesn't seem to have improved performance at all.
AFAIK the Celeron uses the exact same core, just with hyperthreading
disabled.
> My mileage is
The Prescott-based Celeron D chips are quite a bit faster, clock for
clock, than the older Northwood-based Celeron chips. The old Celeron
was SEVERELY data-starved due to the two-fold hit of small cache and
low bus speed. The Celeron D doubled the L1 data cache, improved the
trace cache, doubled the L2 cache and bumped up the bus speed. The
end result was about a 20% improvement in per-clock performance
relative to the old chip.
Still, almost none of that improvement came from any changes in the
processor core itself (though I suppose we should consider L1 cache
and trace cache as part of the processor core).
As I do, and I'm sure that the diminishing returns is part of it.
Still, AMD's Athlon64 die has less than twice as many transistors as
the AthlonXP and it saw a fairly measurable improvement in
performance. Admittedly that was mostly due to integrating the memory
controller, but that simply raises the question of "why didn't Intel
do that?!"... but I suppose that's another discussion that's already
going on in this newsgroup :>
Have you tried updating the BIOS on this board? Just a thought, but I
know a lot of these thermal sensors are VERY inaccurate and are really
just taking a wild guess at temperature. Often time a manufacturer
will have a bug in their temp sensor settings in the BIOS that causes
incorrect temp readings?
Along the same lines, do things inside the case (and/or heatsinks)
seem to be getting physically hot? 47C is pretty warm and should be
noticeable if the ambient air is that warm. On the other hand, if
it's just the processor that they are measuring, 47C is rather cool
and really shouldn't be a problem at all.
You might want to contact Intel tech support on this one. Chances are
that if you have experienced this on a few boards than hundreds of
other people have as well. Intel may have a solution to this already.
Tony Hill
On Wed, 08 Dec 2004 00:19:58 -0500, Tony Hill
Yep, could be - it gets rev'd enough, tho so far the baddies haven't
all been of one particular -40x rev. Saw another one today; system is
fine except it locks on POST after reset; after ATX power cycle, POSTs
fine, etc. Same PSU and other goodies as usual.
>>>Intel more than doubled the number of trans (~55M to ~125M).
Aha! Think software that's more bloated but more reliable because
it's agregated from hi-level blocks, and think post-manufacturing
bugfixing CPUs via microcode pushed by BIOS or OS.
Think XP SP2 vs. Prescott issue, where a Prescott (or P4-EE) left at
Microcode rev 0 by BIOS cause SP2's Update.sys to lock up.
( http://cquirke.mvps.org/sp2intel.htm refers)
I expect some "slackness" where some stuff is left generalized a la
programmable logic array, to be comitted via microcode?
>performance loses).
On "losses", are you referring to the deeper pipelines?
>disabled.
Bloody typical - no wonder Intel pushes P4 so hard, it's money for jam
Intel's been a bit sly in shoving their problems onto other ppl, e.g.
1) BIOS to maintain and push microcode update revs - how many
"required BIOS updates" are actually CPU hotfixes? As it is, the
"blame" for SP2 vs. Prescott has been dumped on motherboard and BIOS
vendors, whereas a date check on Intel's own mobo Prescott readiness
(esp. when in-channel stock versions are also checked) is interesting.
2) Pins on mobo instead of CPU; if the pins bend, it's the mobo
vendor's problem, and that may be another Intel mobo chipset sold
(seeing as Intel won't have to cough that up as warranty fix). Too
bad the user's impact from mobo swap (OS PnP, activation etc.) is way
higher than if it was just the CPU that needed replacement.
In this sense, I'd think of the current overload effect that can
happen when today's mobos meet tomorrow's RAM densities. If that
fries the memory controller, Intel would rather have that as the
motherboard vendor's problem rather than a CPU warranty swap..
Interesting; I haven't rolled those dice, but note the newer board
revs (up to -409, -405 being the Prescott-ready threshold) with
Prescott are running just as hot. Prescott Celeron may run 10C higher
than "old" Celeron, e.g. 57C rather than 47C, and Zone 2 is often only
5-10C behind. So; 47C, 37C is fine, but while 57C may be OK for
processor, 47C is less OK for Zone 2. I've seen Zone 2 crack 50C.
Yes, a hand on the top back of case does feel hot 🙂
I've found it difficult to find an Intel support socket to plug such
formless questions into. I had an Intel marketing droid do a
touch-base (as in "feel free to email me if any queries") but a
synopsis of these concerns brought no response.
Which is why I took my impressions here, to see whether I wasn't the
only one with such issues. It's a certain amount of work to fully
test and document an issue, and that's more difficult when several
boards exhibit flakiness that are not a "hangin' offence" but
nonetheless fall short of even PC Chips expectations.
Dreams are stack dumps of the soul
On Thu, 09 Dec 2004 01:09:43 +0200, "cquirke (MVP Win9x)"
The basic thing I would take away from this is just to avoid Intel
motherboards. I've never been much of a fan, more expensive but
without any improvement in quality. In this case it seems to be a
drop in quality. These days I mostly recommend MSI for good quality
and price, though I've had ok luck with the bargain-basement Chaintech
board I have now (bought it on a whim because it was dirt-cheap).
To a certain extent yes, though the same is true for older P4's and
the PIIIs before it.
>>performance loses).
Yup. There may be some other situations where you could take a
performance hit, but the longer pipeline is the big one.
>>disabled.
Market segmentation. It's the magick behind Intel's profits.
Hmm.. I hadn't seen that one before. It does seem like the sort of
thing that really should have been fixed by the motherboard vendors
with a BIOS update, after all revision 0 is REALLY early on in the
development process and they had probably updated it before the chips
ever shipped. This would be more an issue with people upgrading older
motherboards to new processors without first updating their BIOS,
which is always hit-and-miss.
Of course, the article linked above with a bit light on tech details,
and I couldn't really find just what the actual cause of the error
was.
Fortunately this has turned out to be pretty much a non-issue. It
seems like this might actually be less likely to end up with bent pins
on the motherboard than on the processor.
Hmm.. I think you might be digging a bit too hard for conspiracy
theories on this one, I don't think I've ever heard of memory
densities overloading a memory controller.
The fact that the chips run hotter doesn't seem all that unusual,
though it does seem pretty hot for the ambient air around the chip to
be so hot. Normally with decent airflow you can keep the inside of a
case pretty cool without much difficulties.
Sadly this seems to be pretty much the norm these days. Unfortunately
customers (in general) just are not willing to pay for support, so any
company that tries to offer decent support either has to drop such
notions or goes out of business.
Well, I'm afraid I'm out of ideas on this one. I haven't worked with
the board, so I don't really know any specifics about it.
Tony Hill
Thanks for the URL Chris - it's a good start point for SP2 troubles. OT
for this thread, but have you come across the print server problem with
SP2, where it exceeds the TCP/IP queue request count and purposely goes
into heavy delay?
I have it on a LAN Manager "print server" running Win95 (yeah I know
but....) - SP2 just seems to go to sleep when a print is attempted or even
a printer properties attempt. There doesn't seem to be a registry
paramater - the only "fix" I've seen is a patch to a system file, which is
a bit too ugly for my liking. Turning off the Firewall mitigates very
slightly but the count and action seem to be hard coded in.
Apparently it's breaking print servers from several mfrs but you'd think
that M$ would not break their own stuff even if it *is* legacy.
Rgds, George Macdonald
"Just because they're paranoid doesn't mean you're not psychotic" - Who, me??
On Fri, 10 Dec 2004 01:05:13 -0500, Tony Hill
That was my take, too; I used to prefer generic motherboards based on
Intel chipsets. What changed was a rash of capacitor failures across
a wide range of generic motherboards (Gigabyte, Jetway, DFI), plus
that Intel-branded motherboards dropped into the same price range as
the generics, plus their BIOS became less ideosyncratic.
>>>The extra L2 cache counts for about 30-35M transistors (6
>>>transistors per bit, 9 bits per bit due to ECC and 512KBytes
>>>+ some redundancy). Others are just used for testing and
I'm thinking that the trend is increasing, perhaps. A bit like the
way MS Office bloated up between '95 and '2000.
It's more a matter of motherboard vendors trying to ship
Prescott-ready motherboards before Prescott itself was ready, perhaps.
We've seen this before; remember how some P55C-ready mobos would
wobble the clock speed on iP55C-233, because Intel changed the
electrical behavior of the 200/233MHz jumper? AFAICR what was pull-up
became pull-down, so if the mobo elecronic logic was same as iP54C,
the actual logic (voltage) level was left floating.
The question is: How soon/late did Intel finalize the microcode
revision level(s), and how effectively were these requirements
communicated to motherboard vendors?
One way to see into that, is to look at Intel's own mobo and BIOS revs
in Bayfield, and compare that to what was in the distributor's stock
at the time that Prescott started shipping here. I fed those details
to MS at the time of the SP2 vs. Prescott crisis, but can't remember
them now offhand - but I remember that even after Prescott was
standard, I'd still get served a Prescott-unready mobo rev at times.
I wrote it more in terms of the OS perspective, rather than the
hardware perspective. Not a lot more detail came to light in my
dealings with MS on this; I approached MS, Intel and (in my case)
Jetway, and only MS really fed back any tech detail.
In fact, most of the detail is conjectured from observation :-(
If you do a search at Intel's site for "microcode", e.g. if you wanted
to know what each microcode rev actually fixed, etc. you hit nothing -
it's like the whole process doesn't exist. You get great .pdf on
their own BIOS revs, and processor steppings, and mobo revs too (which
is distinct from BIOS) but nil below the stepping level of detail.
>was.
You can pin it down to Update.sys, which is larger in SP2 than SP1 and
(since I wrote that article early in the saga) which is now confirmed
to push microcode to the processor.
Speculation to why this is necessary, is that SP2 includes DirectX 9c,
which in turn has new floating-point pixel shading stuff. My guess is
that this uses (if available) the new SIMD, which has to be
microcode-rev'd up to work properly. This is the only reason I can
think of, why a Service Pack should care about processor rev.
The reason DirectX 9c is in what is ostensibly a security-orientated
SP2, is likely connected to MS's support policy for "old" versions,
which is geared to SP levels and release dates. I suspect it suits
them to push the latest version of subsystems such as WMP, IE, DirectX
etc. into each SP so that old versions of these can drop off the
support and patching maintenance map.
Speculation as to why Update.sys should lock up, starts from whether
it revs a processor that doesn't need rev (I seem to recall it does
not). If not, then all you need to look for are reasons why the
microcode update should lock the PC - and I'd suspect some sort of
processor state reset that loses context, and thus makes further
processing impossible. I read on a Linux-orientated site that some
microcode revs shouldn't be pushed after POST, for this reason.
You're more hooked into hardware (I dropped out of here until I needed
to come back to ask this question; I've been more involved in OS and
anti-malware stuff lately) so if you can find detail, I'd love to
know. I'm not much of a web maintainer (once I write a page, I seldom
go back to revise it) but if what detail there is is wrong, I'll fix.
>>vendor's problem. Too bad the user's impact from mobo swap
>>(OS PnP, activation etc.) is way higher than if it was just the
I really, really hope so. As it is, I see plenty of old Socket 7 etc.
mobos where the plastic hooks for the HS/fan clips broke off.
No, but what does happen is that certain combinations of motherboard
and RAM don't work due to such issues, and that goes back to i820 etc.
It's easier for Intel to say "you need a better mobo" than "our
processor can't do that". Then again, Intel is heading into
Centrino-style CPU/chipset integration; if the current approach (big
dies with more trannies) is to hold, something has to be found for all
those trannies to do. Else making CPUs could get easy enough for
general chip makers (e.g.. nVidia et al) to climb in.
I haven't seen stock processors cooking up like this since PII-300
maxed out the .35u range, and even then, the rest of the box didn't
cook up. Then again, case makers hadn't tried so hard to regain the
smalller pre-ATX size by crowding the PSU deeper into the box.
I think tech-level support is a cost-effective way for vendors to
tackle this; effectively helps them to pass the buck <g> At one time,
Intel was better at this than MS, but their program became more and
more "small print taketh away", plus they shifted from Q&A at meetings
to no-feedback marketing push, that I lost interest.
MS still does little to communicate directly with small-volume techs
such as myself, though I think what's available on their web site is
way better, but in my case the MVP thing's been very good. In fact,
better comms with techs and builders is one of the things I've pushed
for, where the program has offered the chance to do so.
I've always liked AMD but mistrusted the motherboard chipsets I'd be
forced to build with (SiS, VIA). Noting that AMD's motherboard
chipsets usually use VIA for half the work. Has anything improved
there? What's nVidia's nForce track record been like so far?
Drugs are usually safe. Inject? (Y/n)
On Fri, 10 Dec 2004 19:35:20 -0500, George Macdonald
>into heavy delay?
That sounds like the TCP/IP throttling issue; it usually impacts
peer-to-peer file sharing apps. The intention is to limit the
effectiveness of malware-infested PCs in spreading out malware.
It's a controversial measure, as you can imagine; several scenarios
that genuinely require that traffic are impacted. The fix is to
revert or patch tcpip.sys (I think); a Google on ...
XP SP2 TCP/IP throttling
....should pick up coverage of this. It does!
http://www.microsoft.com/technet/prodtechnol/winxppro/maintain/sp2netwk.mspx#EHAA
<paste>
Limited number of simultaneous incomplete outbound TCP connection
attempts
Detailed description
The TCP/IP stack now limits the number of simultaneous incomplete
outbound TCP connection attempts. After the limit has been reached,
subsequent connection attempts are put in a queue and will be resolved
at a fixed rate. Under normal operation, when applications are
connecting to available hosts at valid IP addresses, no connection
rate-limiting will occur. When it does occur, a new event, with ID
4226, appears in the system’s event log.
Why is this change important? What threats does it help mitigate?
This change helps to limit the speed at which malicious programs, such
as viruses and worms, spread to uninfected computers. Malicious
programs often attempt to reach uninfected computers by opening
simultaneous connections to random IP addresses. Most of these random
addresses result in a failed connection, so a burst of such activity
on a computer is a signal that it may have been infected by a
malicious program.
</paste>
http://www.broadbandreports.com/shownews/56054
http://www.atrevido.net/blog/default.aspx?date=2004-09-22
http://forum.osnn.net/archive/index.php/t-39958.html
Doesn't sound like it fits? How many PCs on the LAN? Remember there
are limits on incoming connections for "desktop" Windows:
- 10: Win95xx, 98xx, NT Workstation, Windows 2000 Pro, WinXP Pro
- 5: WinME, WinXP Home
Actually, SP2 does break some previously-advocated strategies, but IMO
it's a good thing - because those strategies were fundamentally unsafe
in the first place. When IE4 was trying to cadge market from
Netscape, MS basically sold our heads on a platter to web devs; now
that there's anger at just what web devs are allowed to do behind our
back, SP2 sets about trying to stuff the genie back in the bottle.
The irony is, Netscape's lack of these risky functionalities is a big
factor in its comeback. Users like it because it does less (dangerous
stuff) - tho it has holes of its own, and when stress-tested with
invalid or exploitative IFrame etc. it's less solid than IE.
The rights you save may be your own
On Sat, 11 Dec 2004 20:51:20 +0200, "cquirke (MVP Win9x)"
>>into heavy delay?
><paste>
>attempts
>malicious program.
></paste>
Yeah that's it - it's been discussed in various places but the problem is
there is no fix! I haven't looked at his details yet because I'm not real
happy with a 3rd party code patch but http://www.lvllord.de/ has it - only
thing I've found so far.
What doesn't fit? This is our "downstairs printer" which two people use
and it's been working fine for years on our LAN, including with WinXP SP1
as a client. There's something about LAN Manager printing, possibly linked
to Lexmark's connection method, which causes a burst of TCP/IP packets...
which hits the limit. M$'s suggestion to "stop the application" is
asinine... because it's *their* application and there's no way to stop the
damned thing: right click on the printer icon and the bloody WinXP SP2
system goes into a coma. It *can't* be stopped... <tap><tap><tap>........
From what I gather, this is affecting print server boxes from various mfrs
and is going to require firmware upgrades for them... *if* they are still
"supported" by said mfr. At least with SP2's DEP, you can turn it off
selectively or globally; with this you can't even roll back to SP1 on a new
system.
>it's a good thing -
It breaks a lot of things - I've got others like Symantec's Anti-Virus
Corporate Edition V8.01 causing blue screens on shutdown (remember WinXP is
not supposed to err, blue-screen). That one seems to be something to do
with the floppy drive check on shutdown - Symantec promises a fix by end
January... IFF you have their Gold Insurance. In the meantime you're on
your own. Oh and apparently scheduled updates of virus signatures is
broken as well - not something I personally want or recommend anyway.
As for the LAN Manager printing, M$ claims that "Under normal operation,
when applications are connecting to available hosts at valid IP addresses,
no connection rate-limiting will occur." It would be nice if they could
elaborate on what is a "valid IP address" - apparently intra-domain does
not count!
IMO SP2 is the biggest cock-up that's been foisted on the computing
community to date... only demonstates quite clearly how ill-conceived the
whole Windows system really is. A U-turn on what is and is not allowed at
this stage is, quite understandably, causing chaos. Also quite interesting
that this FU is free, when it's the kind of thing which would have been a
pay-for upgrade.
On Sat, 18 Dec 2004 17:29:50 +0200, "cquirke (MVP Win9x)"
>On Mon, 13 Dec 2004 03:04:06 -0500, George Macdonald
>>On Sun, 12 Dec 2004 21:52:22 +0200, "cquirke (MVP Win9x)"
>>>On Sun, 12 Dec 2004 02:00:32 -0500, George Macdonald
>>>I've heard of swapping out TCPIP.SYS, presumably with a "fixed" or
>>>older version (e.g. SP1). Dunno if there are settingsware fixes.
>>What I've read - didn't keep refs - is that there is no registry "tweak"...
>>hard coded, which is unforgivable in retrospect.
>In the context of a post-penetration defence, it would have to be
>hard-coded rather than "Simon Says Let Me Spam" settingsware.
Firewall and DEP are both fully controllable.<shrug> They must have known
about this before release -- may even be one of the issues which delayed
the thing for so long. Just something else for IETF to snigger over if you
ask me.;-)
>>It's not really the printer - it's the WinXP client which is bursting
>>TCP/IP packets, to the server, past its "allotted" limit. A "netstat -no"
>>shows the "flood" clearly - dunno if it's the "server", which is an old
>>Pentium w. Win95B, which is just slow or if its the Lexmark connection
>>scheme which is the basic cause.
>AFAIK the TCP/IP throttling things doesn't go about the size of
>traffic, it's about the number of (unsolicited?) connections. If it
>were an anti-spam equivalent, it would let you send a 10M message, but
>not a 100k message to 100 different recipients.
AIUI the throttling I'm talking about is to do with the number of
oustanding (unacknowledged ?) TCP/IP packets a client is allowed to issue
before it is forced to go "lazy"... which would seem to indicate an
assumption that said client is a potential infector. The kind of thing
this would protect against on a LAN is precisely what happened to us a year
or so ago with a worm (mydoom or sasser ?) picked up outside the office by
a laptop.
>>>No question, there are several incompats and issues; SP2 is
>>>effectively a new OS subversion, so there's all the pain of an OS
>>>upgrade. Hassles fall into two categories; where apps are doing risky
>>>things that SP2 aims to prevent, and other issues.
>>As a user, there is a certain expectation that on an OS upgrade
>...and SP2 isn't supposed to be as "deep" as that, which is why it's a
>nasty shock to find it frets about processor microcode revision...
As above, it's becoming evident why it took so long to get out and possibly
the long delays with WinXP-64.
>>>I haven't heard of that as a generic problem, or even a specific av
>>>product problem come to that. However, we do see lots of hassles when
>>>SP2 is installed over active malware, and several malware do clobber
>>>access to av sites, av updates, or the av app itself.
>>There was no malware involved apart from SP2 and Symantec.🙂
>No history of malware? I ask, because the evil that malware does can
>live after its destruction (many malware defences against av and
>cleanup tools are settingsware, requiring no ongoing malware presence)
A fresh install to a just-built system.
Oh and here's another unfathomable idiocy in SP2: AYK it does not install
a Java VM. Now if you install Sun's Java plugins for another browser and
also allow it to add the IE plugin, the M$ VM gets installed and activated
*BUT* it's the "vulnerable" pre-April '03 VM... so if you turn on Automatic
Updates it wants to download and install the fixed IE VM. YTF did they not
put the fixed VM in the installable set?... utter madness?...
incompetence?... malevolence?.........
On Sun, 19 Dec 2004 01:28:19 -0500, George Macdonald
It does? By what? From what I see, the Sun Java VM is available from
IE, but there's no MS VM present. And yes; Sun's Java VM has
exploitable holes, so you have to ensure that's updated too 😛
Legal constraints, perhaps?
SP1a differs from SP1 in only one respect; it has the MS VM ripped
out, as mandated by the judgement from Sun vs. MS. That prohibits MS
from distributing thier VM, and as you can see, that complicates the
process of MS "fixing" their VM without "distributing" it.
"If I'd known it was harmless, I'd have
killed it myself" (PKD)
On Sun, 19 Dec 2004 17:27:53 +0200, "cquirke (MVP Win9x)"
Well I'm not going to retrace my steps but the "Microsoft VM" shows in IE's
Options/Advanced tab after installing the Sun Java Runtime Environment and
selecting to apply it to Mozilla and IE - no idea whether it was there
before or not but according to the "rules" it should not have been...
certainly now, Windows Update shows that fix 816093 is required:
http://www.microsoft.com/technet/security/bulletin/MS03-011.mspx
On further checking it would appear that maybe neither Sun nor M$ was
responsible for the Microsoft VM getting loaded - no trace of it on the
WinXP SP2 CD. Musta been somebody else🙂... maybe the nVidia Web-based
interface to their Network Access Manager? This is a nForce3 chipset mbrd.
It would appear so.
Windows Update now says that it wants to download and install the fix - so
a fix, which is really a replacement distribution is OK?<shrug> The bottom
line is that 3rd parties are allowed to continue to distribute a flawed M$
VM without hope of the fixed version getting to them, while M$ will supply
the fix as an Update. I just find this whole situation farcical.
