Intel DQ45CB Problem?
Froz3nWaffl3s
72
Hello, I recently purchased a used motherboard on eBay (Intel Dq45cb) and when it goes to start up it seems that it won't start up unless I remove the bios battery and then put it back in. I searched around and someone said they had the same problem and that it was AMT. Any help? Also don't mind the cpu cooler the other one doesn't work so I used mine
https://m.youtube.com/watch?v=RjgKHTJYryg
Your video is unavailable for viewing.
1| Can you please pass on your full system's specs inclusive of the OS that you'd like to install or have installed on the boot drive?
2| Have you tried replacing the CMOS battery with a fresh cell?
