Intel God's "Quick & Dirty" OC Guide to 4.4Ghz with Haswell
Page 17 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
Were you able to achieve stability at 4.4Ghz?
  • Yes
    Votes: 2 3.7%
  • No
    Votes: 52 96.3%
  • Total voters
    54
I never touched overclocking and was wondering if my system would be able to do this...
CPU: Intel Core i5 4670K Haswell @ 3.40GHz with Noctua NH-D14
MOBO: ASRock Z87 Extreme4
GPU: EVGA GTX 760 SC (2GB)
PSU: OCZ ModXStream Pro 600W
What would you recommend for all the values you wrote above.
BrainY I wouldn't go above any clocking that requires 1.25 volts or more with your CPU cooler. If you want to push any more volts than that, you need to be water cooled
Uhhh a friend told me just to overclock without touching the voltages... what should I change then? Just the CPU Multiplier?
I appreciate your input. So basically do whatever IntelGod tells you to do? :-D What if I want to run at 4.0 Ghz or you think I should just go with the 4.4 Ghz anyway? 😀
I got my i5 4670k to 4.2ghz with 1.112 voltage. Is that not pretty good? What voltage should I try first for 4.4ghz or 4.6ghz.
P.S I have set my voltage to dynamic. I think I set it to 1.080 and it upped it for me presumably to keep it stable.
Tetsuya23 You got a pic of the litter chip getting 4.6ghz with 1.26 volts. It took 3.5 volts for me to push a stable 4.6ghz OC. I know its higher voltage than I like, but my temps are good, idle at mid to high 20s and mid to high 70s under a burn test
Can someone give me some advice on fine-tuning my overclock.
AsRock Extreme 4 Z87. I7 4770k. Dark Rock Pro 3 Cooler (Thermal Paste reapplied yesterday)
I have it running stable according to Intel Burn Test (10 runs), settings 4.4GHz, VCore 1.25v, Cache 1.20v, CPU Input 1.9v, LLC 2. Max Temps 83c 80c 76c 73c.
My issue, is that the speed I was getting was 100GFlops to 89GFlops.
I wanted to do this because I bought this system piece mail in 13. Ive had it for 2 years and games like CoD Blops 3 are more demanding. So instead of sinking more money into more hardware I figured i should try OC. I have the intel i7-4770k on an msi z87-g45 board. I noticed there was a button called "OC Genie". I read that it was a "1 sec overlclock." I didnt believe it but tried it. With one button i made the 3.5 into a 4.0. I was happy and noticed a little faster response. However after about an hour of this...i got a zzzzzzt sound followed by the infamous BSOD!
Naturally I went in the bios and turned that thing off and its been fine since. I read that manual oc is the way to go so here I am. I was wanting to try this but I dont want to melt my only form of something to do around here. Thing to consider which I didnt see :
1. I have the cooler master case as in this pic. http://gaming.coolermaster.com/images/products/33/image_620.jpg
2. There are no custom heat sinks except what came with the cpu and board. Stock sinks.
3. How dangerous is YOUR particular setup?
4. Im assuming I should have a backup plan incase stability is an issue and..
5. My machine bsod at 4.0. This guide takes it up to 4.4. Isnt that even worse and more risky for me?
6. When you list what to do, does one assume to "leave every other setting in there on whatever it was?" or....
Thanks,
VAM
PS : Forgive my impudence intel god! I know not what I do!
I've tried a few days to get my 4670k to at least 4.4 but it simply won't.
I was at 1.3vcore
2v input and the highest you set for cache and Nope it won't even start Windows. Do I have a bad chip? Someone wants to help me?
I have a Gigabyte Z87X-UD3H motherboard with a 4670k and I can't for the life of me find some of these settings. I'm probably just blind because I'm new at this, but can anyone with the same motherboard help me out?
All I did was change the "CPU Clock Ratio" to 44 and "CPU Vcore to 1.220v".
I also left Uncore Voltage at stock which was 3.4ghz. I read that you also need to put that to the same value that you changed or a little bit lower, but I'm not sure if that's right or not.
http://i.imgur.com/3dVzbOk.jpg
http://i.imgur.com/tcOHpE1.jpg
I also don't know where the fixed setting is, I think my CPU is set to adaptive since it jumps up and down in AIDA64. Whenever I do the stress test it goes up to 4.4ghz like I want to.
http://imgur.com/a/0R0aQ
Successfully managed to run at least 10 runs of Intel Burn Test version 2.54 without crashing or such.
Asus Z87-A (2103 BIOS)
Intel i5-4670K (unknown batch/serial) forgot to check that. Might do when i replace thermal paste.
CPU Cooler: Noctua NH-9B SE2 with two 80mm Noctua fans.
16Gb G.skill 1600Mhz (XMP mode)
Gigabyte GTX 760 2GB
CPU multiplier: 41
CPU Cache Ratio : 37
CPU Vcore: 1.2V
CPU Cache Volt: 1.2V
CPU Input volt: 1.9V
DRAM Volt: 1.5V
BCLK: 100Mhz
Sync all cores
A lot of settings on Auto or the default value.
Windows 10 Pro X64
Running Asus AI-suite III that might interfer with BIOS settings.
All other things are based on (Load optimized defaults) with some minor changes.
Intel Burn Test: 8.4 seconds per test, 106.4 GFlops per test, Stress level Standard, Threads all
Temps in HWmonitor: 83-87*C on all 4 cores.
