Question Intel i5-4460 CPU Running at Extremely Low Frequency (800MHz)
Jan 20, 2025
I'm experiencing an issue with my Intel i5-4460 CPU, which is currently operating at a significantly low frequency of around 800 Mhz instead of its expected 3.2 Ghz and I cannot manually change the frequency in the BIOS.
Attached Screenshot
Additional Info:
- I have recently replaced the PSU to a new one 2 days ago.
- I installed the Gigabyte App Store and installed Easytune and SIV a day ago.
- After installing the new PSU, the system was performing good and the CPU frequency was around 3.2 Ghz. I've only noticed low system performance after installing Gigabyte App Store, EasyTune and SIV. Could it be posible that Easytune has something to do with it?
I have tried:
- Checking the Cpu frequency on my motherboard BIOS. The setting is grayed out and I'm unable to change it.
- Uninstalling the Easytune and SIV and restarting the computer.
Nothing has worked so far, can someone please help me out. I have a lot of office work to finish tomorow and I'm unable to work due to the reduced system performance 🙁
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
Please mention make and models of all parts that were replaced or swapped. Did you clear the CMOS? You're advised to disconnect from the wall and display, then remove the CMOS battery, press and hold down the power button for 30secs, then reseat the battery after 30mins.
PC Spec:
CPU: I5-4460 3.2 Ghz
CPU cooler: (Came with the CPU)
Motherboard: Gigabyte H97M-HD3
Ram: 16 GB (2x 8GB kingston DDR3)
SSD/HDD: (1x 118GB SSD) (2x 500 GB HDD)
GPU: GTX 760 ti (bought a few months ago.)
PSU: Gigabyte P450B 450 W (brand new, bought just two days ago)
Chassis: MSI MAG FORGE 100R Mid Tower
OS: Windows 11
Monitor: Samsung s3 s36c
I have removed the CMOS battery after disconnecting any external cables. Pressed down the power button for more than 30 secs, and re-installed the batteries. But nothing has changed.
Alright, I have changed the PSU with no avail, It's definitely not a power supply issue.
Well first you really need to go into bios. That screenshot is not the bios screen.
You have to press the delete button several times after pushing the power button to even go there, and some times you have to disconnect the drives because sometiimes its hard to get into bios.
But to reset that board, you unplug the computer, open it up, and place the jumper on the pins called "clear cmos" and remove the jumper, then plug it in and turn it on. This will reset the bios and load the processor profile from scratch.
Since this is one of those low quality sites you can't post pictures, I cant show you directly a screenshot of the manual, but here is the link to the gigibyte site so you can download the manual and look at it. The bios screen is on pg 18:
GA-H97M-HD3 Manual
