Intel P4 2.8GHz 400MHz FSB 478pin 512K Northwood CPU
Daconiam
29
Can't afford a whole new system..... Is the Intel P4 2.8GHz 400MHz FSB 478pin 512K Northwood CPU worth upgrading to and is there a cheap place to find one? I think that is the fastest CPU w/400MHz FSB.... Already have 1gig of memory coming.
I currently have:
P4 2.2 NORTHWOOD
845D INTEL CHIPSET
512MB RAM
120GIG HARD DRIVE
GeForce 6600 256MB AGP
Thanks in advance!
I could be wrong..
but from my point of view, having 600MHz boost isn't that great.
I mean, nth change, FSB is still 400, L2 Cache is still 512..only thing changes is multiplier...i don't think the performance would increase by that much.
P4 is a bandwidth hungry processor, at 400FSB, the performance is quite limited.
The computer is just the "family" computer. Mostly internet browsing with some tinkering with Adobe photoshop. I do have Doom3 and plays ok but I am not a big gamer or such. Just want to speed things up a bit without going for an entire rebuild or a new system.
Is there something unsatisfactory about the PC you currently have? I'm not an expert, far from it, but before I built my new PC this winter, I had a Dell Dimension 2100 with a 1.1Ghz Celeron... It seemed fine with internet browsing and Photoshop (OK maybe the stuff loads kinda slow). I even played some Counter-Strike or Halo (didn't run well) on it. From the specs you list, I would consider that a dream for what you're using it for.
It is time to raise your fsb.
By raising the fsb from 100 to 115, you will be able to equal or surpass the performance of a new 2.8ghz chip ona 100mhz fsb.
Many people with your chip were able to run stable at an fsb of 133.
I dont suggest you go that high, but 115 would be fine.
FYI the 2.8 northwood A was a limited production chip made primarily for an OEM. They are hard to find, and not generally worth the price.
Agree with most people here... There's no point spending money on that chip. Raising FSB as endyen suggests is definitely worth having a go at though. That's overclocking of course, so you may want to do a bit of reading in the overclocking forum. I think there's a sticky 'guide' thread to overclocking P4 chips.
Well it appears I am stuck for now. I have the Intel D845BG mboard and it is not overclockable 🙁 . I will settle for more ram for now and start saving some money to build one. I will keep my eye out for a cheap mboard upgrade as suggested by Supremelaw. Should be lots of stuff out there on eBay or a computer show.
l8r.
Thanks to all!
I am also looking at purchasing the same processor for my computer
Pentium 4 1.8 Ghz
768 MB ram
160 GB HD
eVGA GeForce 6600GT video card (waiting on backorder)
I've only found one place that has it ($219). Worth it for my system?
