Intel(R) Core(TM)2Duo CPU E7500 @2.93Ghz is 64-bit or 32-bit?
dkaran
:??: there is 32bit operating system installed in my PC. i want to know whether the Intel(R) Core(TM)2Duo CPU E7500 @2.93Ghz is 32-bit or 64-bit,,,to install a 64-bit operating system!!!
Thanks for your giving me valuable time and answer.
from intel's webpage on e7500:
http://ark.intel.com/products/36503/Intel-Core2-Duo-Processor-E7500-%283M-Cache-2_93-GHz-1066-MHz-FSB%29?wapkw=intel+core+2+duo+e7500
check the 'instruction set' section. it says 64bit. that means your cpu can run both 32 bit and 64bit instruction. so if you want to install a 64bit operating system, go for it. your cpu can run 64bit os without problem.
Intel® 64
Intel® 64 architecture delivers 64-bit computing on server, workstation, desktop and mobile platforms when combined with supporting software.¹ Intel 64 architecture improves performance by allowing systems to address more than 4 GB of both virtual and physical memory.
supports both :)
