juanrga :
AndrewJacksonZA :
@juanrga: your sig says "I like/dislike tech, not companies!" but what seems to be your attitude, your focus, and your word choices aren't backing up that claim. (If you aren't a native English speaker, my apologies, this third point might not be on purpose.)
Direct quotes from the page of the page in the TweakTown article that you linked to:
"However, the kicker is, you would also be paying 78% more for the 7960X, meaning you would be getting 30% more performance for 80% more cost."
"Once you remove buyers who value "price vs. performance", then you get into another subset of buyers. However, if you need 16 cores, and you don't want to sell a kidney for it, then at stock the 1950X is an extremely powerful option, especially for its price. If money is not an issue (for most it is), then Intel does offer a bit more."
"There are other factors to take into account, and this article isn't about telling you which CPU to buy, rather it's looking at how AMD's microarchitecture is doing against Intel's in the high-end desktop segment, so far, quite good."
________________________
Are you perhaps excluding price from your thinking? If one excludes price, then yes, Intel's chips would defintely be the better buy for some use cases. If one includes price in the equation though, Intel doesn't have a leg to stand on in the slightest.
I was showing that the IPC gap between Intel and AMD is about 30%, despite certain biased sites using tricks to reduce the gap. I was also showing that this review confirms that Intel is more efficient even overclocked.
I wasn't discussing prices. My main interest is
technology, not prices. Also as explained a hundred of times, performance is not a linear function of price. So getting 30% more IPC costs about 70% more from an engineering point of view. The company that targets lower performance almost always has a price advantage. So I give zero merit to AMD for winning in the price/performance metric.
Of course, this nonlinear relation between price and performance also applies to other engineerings. Not everyone looks for the best price/performance ratios. No one is purchasing a 400Km/h supercar because it has the best price/performance ratio...
Let's not over hype the comparison. This review is an outlier favoring Intel compared to many other reviews. Gamers Nexus who test 7960X CPU against the 1950X show huge power consumption differences at the EPS( upwards 50% more overclock) and used delidded 7960X.
Let's look at the test set up first:
Cooler: Enermax TR Liquitec 360 and Corsair H115i AIO Water Cooler
The 7960X used the 360mm cooling solution!
The Intel 7960X is clocked up to 4.0GHz using multiplier only overclocking. Memory speed is increased to 3200MHz per XMP, using the same exact kit that was used for the Threadripper testing. The Threadripper system also had its infinity fabric increased in speed by 50%, so I went ahead and overclocked the mesh speed from 2.4GHz to 3.2GHz, which is a 33% increase. An input voltage of 2.1v was used, and LLC was turned on. A fan was blowing right over the VRMs, and the radiator fans were always blowing full speed.
He states Infinity fabric was overclocked, this is by product of the uArch(which was deemed by most as a weakness and it now viewed as an unfair advantage) by virtue of simply putting in a stick of RAM and having it work at it's rated speed. Bios settings had to be manipulated to overclock the mesh! Intel's VRMs had to have a fan blowing right over the VRMs, and the radiator fans blowing at full speed just too get this thing to run at stock speeds without thermal throttling. This has been demonstrated on multiple reviews!
https://www.tweaktown.com/articles/8379/amd-threadripper-vs-intel-core-i9-cpus-clock/index2.html
Now let's look at the benchmarks, and what all went into those overall numbers even after seeing the test setup heavily favors Intel with solutions that most users will not see out of the box!
@4GHz Single thread performance difference is 12 points or 7% in favor of Intel, and multithread of 75 points or 2% in favor of Intel. Let's not forget the quote that comes later:
The price gap remains, so the Intel costs roughly 80% more.
Looking at cooling involved a 360mm radiator and a fan blowing on the VRMS, and relative small performance gains not worth a cost of 80%. But that's just the first test! Let's look at the second test!
@4GHz there is a 1.5 point or 3% gain over the 1950X
Here we are with one of the test that are factored into overall performance that was used to come up with the 24% productivity and 31% overall! Really?
@4Ghz the 1950X is 8% faster at copy and 13% faster at write while being 15% slower at read. Still not seeing that 24% better in productivity!
We see that clock for clock AMD's Threadripper equals Intel's Skylake-X in 64-bit integer IOPS, but in SP FLOPs it is half as fast, but we saw the same type of activity at stock. Memory bandwidth is an interesting thing, AMD's reads and writes are faster, but Intel's copy is faster. Intel's memory latency is superior, but that is because Intel doesn't have an Infinity Fabric
@4GHz AMD is 3% faster than Intel.
And here we go at
720p transcoding we see Intel gain 18% over AMD. They throw in a benchmark that greatly favors Intel to help Intel get that 24% better productivity. I wonder how many people buying $1,000 plus CPU's will be doing 720p transcoding? They don't even mention 720p in the commentary.
AMD had the lead in Handbrake 4K encoding at stock and maintains it in our clock for clock tests, but the margin is smaller. Intel had the lead in Handbrake transcoding, and the margin is still maintained when they are equalized.
@4GHz we see Intel take the lead in overall performance by 17%, still not seeing that 24% productivity performance increase here.
@4GHz Intel takes away a good win here performing 25% better. And that concludes all the "productivity performance" benchmarks. So, the majority of that 24% increase over AMD comes from synthetic benchmarks affected by memory latency.
In ScienceMark Intel's offering is faster. In SuperPU we see Intel's offering is significantly faster, and that isn't just because SuperPI is a single core benchmark, it also greatly relies on memory latency (where Intel shines).
And I still don't see where they get that 24% productivity performance increase! They must really give a lot of weight to Aida64 FPU Test for single-precision FLOP's where it out performed AMD by 50%!
Read more:
https://www.tweaktown.com/articles/8379/amd-threadripper-vs-intel-core-i9-cpus-clock/index4.html
Now let's take a look at the same type of difference at the 4GHz clock for clock. The price gap remains, so the Intel costs roughly 80% more. We see Intel offer roughly 31% overall, 36% gaming, and 24% productivity performance increases over AMD. Compared to stock, Intel's margins increase 2% overall in overall performance and 8% in gaming performance. However, Intel's margin in productivity decreases from 28% to 24%, meaning Intel's margin over AMD at 16 cores has decreased 4% in productivity applications. However, while Intel's power consumption was 12% higher at stock, it's now 16% higher overclocked (includes idle and load). Putting the Intel 7960X and AMD 1950X head to head, clock for clock, reveals three major trends. Intel's performance gains over AMD's decrease in productivity applications, but increase by a larger margin in gaming applications, resulting in a slight increase in overall performance. At the same time, Intel's power consumption increases 4% while overall performance margins only increase 2%-3%. There are other factors to take into account, and this article isn't about telling you which CPU to buy, rather it's looking at how AMD's microarchitecture is doing against Intel's in the high-end desktop segment, so far, quite good.
This is another heavily Intel bias review using better cooling, bios manipulation, and using cherry picked benchmarks to favor Intel. The review remains an outlier.
