Internal clock speed
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
when I am running programmes including Typeitin the speed of pc can change
in extreme examples it slows down so much that a re-boot is the only cure or
a 120 second counts down takes less than a second
I didnt have this problem prior to installing service pack 2, is this the
cause ?
"wrp" <wrp@discussions.microsoft.com> wrote in message
news:1E1D10B3-466B-4A69-A4BB-677852DBCEBE@microsoft.com
> change
> cure or a 120 second counts down takes less than a second
> the cause ?
Good Post:
http://dts-l.org/goodpost.htm
Getting Your Post Noticed -- and Answered
http://www.microsoft.com/presspass/features/2001/Mar01/Mar27pmvp.asp
How Not to Get Help in Newsgroups
http://users.tpg.com.au/bzyhjr/liszt.html
Frank Saunders, MS-MVP, IE/OE
Please respond in Newsgroup only. Do not send email
http://www.fjsmjs.com
Protect your PC
http://www.microsoft.com/security/protect/
> cause ?
Is this a portable system? Some of the mobile processors will operate on a
slide scale - less cpu cycles for lightweight tasks will preserve the life
of the battery.
However, what you're describing sounds more like a bottleneck. A "backup"
of processing tasks -- each waiting their turn to make it through the
available data pipelines. While XP is not sensitive to resource use in the
same way as Win9x was, it can only perform within the parameters of the
hardware provided. Examples: Not enough RAM will cause more paging and
limiting the page file can stonewall performance at unexpected times.
Suggestions: Using "let windows manage" in the memory management section of
system properties> Advanced, works best for most situations. You can use
Task Manager to pinpoint what programs are demanding more CPU cycles, which
are using more RAM. End task on heavy hitters when you are going to work
with a heavy duty program.
Sharon F
MS-MVP ~ Windows XP Shell/User
