[SOLVED] Internal hard drive auto disconnect and reconnect while using
Dec 26, 2021
My hard drive automatically disconnects and reconnects for 3-5 seconds while using. Already applied so many methods still couldn't find the solution.
My config
CPU: Ryzen 3 2200G
Motherboard: AsRock B450M Steel Legend
Ram: 2x8GB 2400Mhz
GPU: Gigabyte 1660s 6GB
STORAGE
1x SSD transcend 250GB (Windows directory)
3x HDD
Western Digital 1TB 7200RPM
Toshiba 1 TB 7200RPM
Seagate 1TB 7200RPM
Power Supply
Antec 550 Watt no modular PSU
I failed by applying these methods below
  1. Changing cables and connectors (Not solved)
  2. Doing some changes in Power management (Not Solved)
  3. Re-install windows (Not solved)
Please I need a permanent solution. I am a freelance video editor and this is so annoying. please help me.
Actually, this happens with only one HDD (Seagate) If I remove it everything runs smoothly. But my question is how can I verify that my HDD is faulty so I can claim a warranty.
If you have tried a different power and data cable and a different sata port on the mobo and you still have the problem contact seagate and have a chat.
My config
CPU: Ryzen 3 2200G
Ram: 2x8GB 2400Mhz
STORAGE
3x HDD
Seagate 1TB 7200RPM
Power Supply
Replace the hdd....test.
