Question Internet/ethernet problems.
A virus could cause those symptoms. Have you scanned for them?
Open a cmd.exe window and run ipconfig.exe /all capture the text and post the results.
its a fresh windows
Microsoft Windows [Version 10.0.22631.2861]
(c) Microsoft Corporation. All rights reserved.
C:\Users\binks> ipconfig.exe /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-TT22EEA
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : broadband
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : broadband
Description . . . . . . . . . . . : Intel(R) Ethernet Controller (3) I225-V
Physical Address. . . . . . . . . : E8-9C-25-C3-91-ED
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::2362:982a:2f04:e166%17(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.63(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 17 April 2024 03:57:43 PM
Lease Expires . . . . . . . . . . : 24 May 2160 10:31:37 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 166239269
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2D-B0-53-0F-E8-9C-25-C3-91-ED
DNS Servers . . . . . . . . . . . : fe80::d635:1dff:fe7c:f2db%17
8.8.8.8
8.8.4.4
NetBIOS over Tcpip. . . . . . . . : Enabled
Connection-specific DNS Suffix Search List :
broadband
Wireless LAN adapter WiFi:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : MediaTek Wi-Fi 6E MT7922 (RZ616) 160MHz Wireless LAN Card
Physical Address. . . . . . . . . : 74-97-79-FF-98-A5
Wireless LAN adapter Local Area Connection* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 76-97-79-FF-B8-85
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 76-97-79-FF-A8-95
C:\Users\binks>~
its a fresh windows
8.8.8.8
8.8.4.4
broadband
C:\Users\binks>~
To simplify things, I would recommend that disable IPv6 in your ethernet adapater properties. That might fix it, or it might not. But it does simplify things.
It is interesting that the first DNS server you have is an IPv6 address. Disabling IPv6 will eliminate that.
should i restart my pc after?
still didnt fix it i still get the errors
You say this is a "fresh windows" install. Where did you get the installation files ?
If you got the install from anywhere except Microsoft.com you could still have malware/virus.
Have you scanned for malware/virus ?
i haver scanned for malware and virus
2024-04-17_16:32:44 Checking user locale: en-GB.
2024-04-17_16:32:44 Locale 'en-GB' wasn't found.
2024-04-17_16:32:44 Checking user locale: en-US.
2024-04-17_16:32:44 Setting user preffered language: en-US.
2024-04-17_16:32:45 Failed to read and parse installer embedded payload
2024-04-17_16:33:35 Won't get meta, invalid repo path provided: https://www3.corsair.com/software/CUE_V5/public/modules/
2024-04-17_16:34:29 Failed to get mpid value
2024-04-17_16:34:29 No metadata ready for: https://www3.corsair.com/software/CUE_V5/public/modules/
2024-04-17_16:34:29 Invalid repositories provided, or no internet connection.
What do you get if you click on "open logs" ?
The URL listed -- https://www3.corsair.com/software/CUE_V5/public/modules/ If you open that in a browser do you get a blank page with "Not a file" ?
If that is the case, I don't think your problem is a network problem. I think the error message is misleading.
IS it possible the time on your PC is VERY wrong? That can mess up https:// access.
Here is an article on windows update that shows the URLs that need to be accessible -- https://learn.microsoft.com/en-us/p...nd-2008/cc708605(v=ws.10)?redirectedfrom=MSDN You should be able to verify that you can get to them by using a cmd.exe windows with the nslookup.exe -- remember to remove the http part of the of the URL to do an nslookup
I dont understand how to do that with firewall
Do you believe you have a firewall that is blocking?
If it is local to the host, temporarily disable it. That will eliminate it as a problem. It is UNLIKELY that a firewall is your problem.
As I said, is the time correct on your PC ?
yes time is correct
