I just Joined The community in Hopes That I might Get Help!!
I need To change my Ip Using "Ipconfig/release and ipconfig/renew" through Cmd prompt!!
Now before u tell me to Switch oFf and Switch On my Modem, i have to say that sWitch off and On Methos Works perfectly Fine for me!! my Ip changes every time i do it!!
But the Problem is switching On my modem back again takes About ten minutes Solid untill all the lights Are On.... and it really gets on my nerves everytime i have to Do it!!!
So i want to Use this ipconfig/release renew feature...
i have been through many help forums over the Internet regarding this and tried The following---
* I have Changed/spoofed/cloned My Mac Address Successfully!both through My OS (Xp Sp2) and through Router Configuration.
*I Have Set Lan Connection Properties to Automaticlly Detet Settings
*I Have Set Tcp/Ip propeties to automatically Obtain Ip address and Dns server address
Router Settings:
*ISP is Set to PPPoA/PPPoE
*DHCP is Enabled
*Router Firewall is Disabled BUt Normall Windows Firewall is ON!!
*Ip address is Set - Dynamic IP
*NAT is Enabled
*Connection is Set to "Always On" (not Connection on demand or manual)
*In NAT sessions "Single IP" is Set (i donot know what that Is) the another Option given is Multiple Ip
*ACL is activated ( i have no knowledge Of that Either!! but Wiki says "Access Control Listing")
Things I havent Done -
*Disable NAT - Some forums Suggested I Do it but Some other forums claimed it is Dangerous and it would open up connection Completely , make it vulnerale for attacks!!
*Run the "Windowsfixit.Exe" program .... My friends told me to run the program but as per certain forums it is Useless if if could already get a Dynamic Ip change through Swtich off and Switch ON!!
My Ipconfig diisplays an Ip Starting With 192.168.1... which I presume is the Internal Ip of my Computer that would mean the External Ip Assigned is Taken up by the Router!!
Now one of The forums Gave Instructions that unless i Could get my system to get that External Ip to my Computer and Not the Router..
release and renew method would keep Failing!!
I Donot Know if this is true or to get external Ip to my comp (if It is True)!!
I have been trying to make "release and renew" method to Work for about Three Months but to no avail....!!
Hopefully if u guys could help me achieve it!! 🙁
Thank u in advance!! 😗
Note--
I use avast antivirus and malwarebytes antimalware as a supplemantary!!
Avast Doesn block any sites or Connection but it does run a Script Virus scan before Connecting to any site even if it is Google!!( if it should be a matter of Consideration)...
I only use Malwarebytes Antimalware Occasionally!!
