Is 20 Degrees for CPU too low or normal ?
omidelf
342
when i only browse internet my cpu temp goes as low as 19 celsius degrees (i7 6700k with watercooling)
was wondering is this normal ? can i run into any problem if it is this low ? or the lower the better ?
I think it's fine, since it's watercooling (and I suppose you didn't overclock) it should be possible. Do know that temperature readings on CPU's are not always a 100% accurate in software and in BIOS it won't show temperatures under true load of the OS and programs.
What is the ambient temp of the room?
Watercooling or no, it can't be below the actual room temp.
Also, idle reading are often off by quite a bit.
