Question Is 43°C too hot for a processor at rest ?
Jul 8, 2022
16
Hi, I have just installed my second PC with an i3-12100-F and I notice that there is a problem with the processor temperatures. I changed the original thermal paste with Artic MX-2 and I feel like I lost a few degrees. I then run a test with OCCT for 10 minutes and I reach the temperature of 88°C, which is huge! Do you know if this processor is known to have high temperatures ?
Jekama
Well, running a stress test is one thing.
Are you using the included cooler? It is fine, but not really meant to keep it cool under OCCT.
Depending on ambient temperatures, 43C might be normal. Going to be above ambient, and depending on how the cooling in the chassis is, the inside of the case might heat up. You still need sufficient airflow, even with a low power system.
Yes, at max boost Alder Lake chips do run hot, but you kind of want them to, to deliver maximum performance.
Yes, I use the included cooling system. So I understand from reading you that the temperatures I have are normal. Thank you for responding so quickly!
Jekama
I performed the test with a "large" dataset, normal mode and a constant load type. And this morning I notice that at rest I am approximately in the 50 degrees and not the 43 degrees as yesterday. Shouldn't I be worried ?
Jekama
If you use the stock cooler, then there is no issue, no. They are pretty bad, just good enough to keep the CPU running. If you want better temps, you will have to get an aftermarket cooler. Even cheap ones for 20-30 will do a much better job than the stock cooler. Btw, optimal peak temp in stress tests is somewhere between 80-85°C for most people, and the maximum your CPU is allowed to get to according to specs is 100°C. So you aren't far off from optimum and a decent way off from it getting too hot. If you want to improve temps without a new cooler, you could take a look at undervolting. If your mainboard won't let you do that, Intel XTU is a great alternative. Also for realtime experimenting with it.
Also, the thermalpaste is pretty irrelevant, btw. They show little difference between the different brands.
I think I will buy a BeQuiet! Pure Rock 2 Slim for 29€
Reactions: KyaraM
